Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Aug 2010
    Barrie, Ontario, Canada
    That is a great all round lake boat. I had a 1987 18'6 panther with a 175 opti that would see 70 with a 27 Tempest. Your boat is a little larger so maybe try a 25 pitch and hope for 65-68.
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  2. Thanks LukeReid thanked for this post
    Likes LukeReid liked this post
  3. #17
    Sep 2017
    ontario
    Nice - I agree . Little hot rod to ski behind - enjoy
  4. Thanks LukeReid thanked for this post
  5. #18
    Aug 2021
    Ontario Canada
    Quote Originally Posted by V-bottom View Post
    Thanks so much for the suggestions. I am definitely going to play around with a few things and I will try out a different prop as well.
  6. #19
    Aug 2021
    Ontario Canada
    Thank you for all the information. I am going to play around with a few things for the rest of the summer and will be doing some work on the boat and motor over the winter months.
    The engine was redone about 7 years ago by Speedmaster Marine so I have reached out to them as well to see exactly what work was done on the engine.
  7. #20
    Aug 2021
    Ontario Canada
    Black boxes are are electric idle/timing modules that adjust timing and get wonky often which burns down your motor. Delete them and set timing through the lync and synch process. Search out the info here it’s a common thing. Water pressure gauge as mentioned is also wise if raising motor up. Finding the ideal prop for your rig is a ton of fun and you’ll find you will have props for cruising, and props for running hard. In the end many of us run around a 24 pitch for ripping around and around 28 for top speed runs. 17 pitch for skiing
    choppers, trophy, tempest, fury, et, all good runners
  8. #21
    Jun 2018
    Floating around
    I think you'll find the set up is far more crucial than the engine power level. If its a good runner, thats all you need. I took a 75 on my Vandal from mid 40's to almost 60 just by messing with engine height and props and driving. Its a lot of fun working the set up and props are basically cost free if you keep them in the condition you buy them in they will sell at the same or close enough to price that its not a worrying expense. Beware though, its easy to start hoarding good props lol
  9. #22
    Central, PA
    Beautiful boat you bought! The oil tank and the black boxes that Lake was talking about are a must, simple job. As far as the pulling problem on deceleration, agreed that a ratcheting lower would help, but if that's not in the cards at this time, a jackplate will ease this up alot with engine height. That also leads to adding a low water nose cone on the lower for water pick up.
    Keep this thread going with any questions and updates and there are many many knowledgeable speedfreaks here who can help you achieve your end goal
  1. check mate 25
    By jef in forum Hulls larger than 20'
    Last Post: 01-15-2016, 11:08 AM
  2. wtf mate, nukes?
    By Pro300x24LD in forum The Scream And Fly Lounge
    Last Post: 09-14-2009, 08:04 AM
  3. Panther Ski Mate 2? Need info fast!!!!
    By LikwidCourage in forum General Boating Discussion
    Last Post: 07-15-2005, 09:12 PM
  4. the state of my mate
    By jmdank in forum Fiberglass and Composites Discussion
    Last Post: 12-18-2003, 02:08 PM
  5. Checkmate V-Mate
    By hwyrnr in forum General Boating Discussion
    Last Post: 10-14-2002, 08:08 AM
