Results 46 to 60 of 65
Thread: Phantom 25 1985 - Merc 450R
08-01-2021, 09:41 AM #46
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
This is absolutely what is happening. The heat itself isn’t likely to damage anything unless it’s well over 200 deg F. The hottest I measured was 120 F when I was messing with it. The viscosity of Mobil1 0w30 drops from about 120 cst to 45 cst when heating up from 80 deg F to just 120 deg F. The oils I was entertaining, but never tried, were Mobil1 0w50 and Shell Morlina S4 B 100. Both hold their viscosity better at high temps, but I believe the Morlina is better suited and higher quality base oil. At 120 deg F the viscosity of both the alternatives is 70 cst.
Toffen thanked for this post
08-01-2021, 09:48 AM #47
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 7,018
- 681
- 1102
- 1926
- 7992
- 4 Post(s)
There is never going to be more torque against the system then with a single application (twins, triples, and quads all have motors to counter act against each other) and are run much lower and with much smaller propellers. My set up is as high as I can go and still get water pressure (my modified case will be another 1 1/4" higher) and I am running a 15" X 34 5 blade merc. cleaver. Mine was fine last time out until it blew a line fitting.
My next project is an LCB with a 300R and a side ram. I am going to use the sea star power assist with a sea star helm and stainless lines as have many times now and see how it acts.
08-01-2021, 10:35 AM #48
5000 RPM
- Norway
- 954
- 63
- 17
- 358
- 196
Hi,
So the lesson is to mount a oil cooler in the return line. I will ask my dealer to replace the oil and bleed properly. I have been told that the oil Merc is using is the Mobile One 0w30. I have asked some folks in the oil business in Norway to come up with some ideas.
Would it any point to go back to my old pump? Maybe the added speed and torque from the 450R will create the same problems with the old pump.
Cheeers, Toffen
08-01-2021, 12:19 PM #49
Supporting Member
- Apr 2003
- 7,018
- 681
- 1102
- 1926
- 7992
- 4 Post(s)
The new pump was designed because the old one didn't have the capability of keeping the motor straight at speed without being overworked and giving feedback. Keep the new pump just make sure the fluid is correct and put a large cooler in the return line-let us know your results.
08-01-2021, 03:50 PM #50
5000 RPM
- Norway
- 954
- 63
- 17
- 358
- 196
Hi!
Anyone out there knowing where to get hold of a oil cooler for the return line?
Thanks
Cheeers, Toffen
08-01-2021, 04:35 PM #51
08-01-2021, 07:31 PM #52
Supporting Member
- Apr 2003
- 7,018
- 681
- 1102
- 1926
- 7992
- 4 Post(s)
https://www.summitracing.com/parts/sum-331000
This is strictly an air cooler. You are not running water to like Cuda is recommending above.
08-02-2021, 04:14 PM #53
Very timely post. I ordered a cooler today.
In addition, it turns out Merc recommends the 40cc version for single engine boats. The 40cc on a high performance V-hull is slow to respond and difficult to drive. We are going to switch to 50cc.Allison XB21 2+2
08-03-2021, 07:55 AM #54
5000 RPM
- Norway
- 954
- 63
- 17
- 358
- 196
river rocket liked this post
08-03-2021, 08:41 AM #55
Never once had an issue with the Seastar power assist. The only time I had an issue was the one time I used a Verado pump. Could be the extra heat is because the Verado pump runs full time and the Seastar does not.
Boat Delivery available
Things owned. NOTHING!!
08-03-2021, 08:59 AM #56
5000 RPM
- Norway
- 954
- 63
- 17
- 358
- 196
08-03-2021, 09:13 AM #57
I use the PA1315 or PA1200. The 1315 provides more pressure, but the 1200 works great too. The pump only runs when the wheel is turned. I put them on every single boat in the last 5 years. Probably 30-40. Never had an issue. For twins, I always use the IMCO pump. It does run full time, but I never had an issue with it either. I sell all the IMCO stuff
08-03-2021, 10:31 AM #58
5000 RPM
- Norway
- 954
- 63
- 17
- 358
- 196
08-03-2021, 11:18 AM #59
I run the IMCO pump with twin outboards. I have had it overheat on me one time. After a phone call to IMCO, they told me that if there is not enough air circulating where it is mounted it will overheat and shut off till it cools down. I had sealed all the openings to the back of the boat to prevent Salt water spray from getting back there. He suggested to run a small electric fan blowing on it to keep it cool. Works great now.
I only run the fan when I am racing and putting it through constant stress for extended times. Never has it overheated on any regular day trips or top speed runs.
This is on twin 300xs, but still was able to get it hot enough to shut off on me.
Love the IMCO system and how it feels and responds to the smallest of movement of the steering wheel.
Michael
08-03-2021, 12:59 PM #60" IT'S NOT HOW FAST YOU ARE, IT'S HOW COOL YOU LOOK!!! "
Phantom 25 1985 - 450R
By Toffen in forum Props, Setup, and RiggingReplies: 5Last Post: 11-18-2020, 02:31 PM -
Engine height Merc 450R
By Toffen in forum General Boating DiscussionReplies: 19Last Post: 08-14-2020, 09:24 AM -
Merc 450R
By Toffen in forum General Boating DiscussionReplies: 4Last Post: 05-22-2019, 06:29 PM -
1985 Hydrostream Vulture 1985 Mercury 200 hp Black Max $5,900 obo
By sunsport197 in forum Hulls up to 20'Replies: 2Last Post: 07-10-2015, 09:11 PM -
Phantom 25 w/twin Merc 2.5 EFI SS - search for speed
By Kim Heidi in forum Props, Setup, and RiggingReplies: 0Last Post: 09-17-2007, 02:01 PM
