Results 1 to 15 of 30
    Who wants to speculate on what happened to THIS prop?
    I don't think this one can be repaired.
  2. Likes scott reierson liked this post
    45 Post(s)
    I would like to say that its a crystaline failure in the blade root but the blade in the 7 o clock position is heeled over. The fracture line in all the blades is nearly identical. Did you hit something? No.
    Pekin, IL
    I have destroyed many props over the years but very few done that well. Congratulations for a job well done.
    Rock
    Team Junk
  5. Likes JBS, DanUmbarger liked this post
    how could it fail first time out..must be warranty...
    Feb 2003
    Rochester, NY
    Interesting that the skeg and gearcase look untouched. Also appears to be a two engine installation. Hmmmm.
    1992 Progression 22
    Mercury Racing 250R
    Western Pennsylvania
    Lab work... reduce diameter to get engine in RPM range!
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  9. Likes powerabout, kellytheaker, bullhead00 liked this post
    MIAMI FLORIDA
    Blades are bent at the leading edge opposite of rotation so it was in reverse or the r/h prop is also destroyed
    When the prop meets the road......
    8 Post(s)
    Jaws is still alive and well.
    May 2016
    keys
    Quote Originally Posted by sharpeye Mike View Post
    Definitely sharks!
    ANTI40​It's just an idea.
  14. #11
    Oct 2009
    Gonzales, La
    Smile
    Man that’s an interesting failure. I actually don’t think it was caused by impact with an immovable object. Looks to me like a fatigue failure. The crack initiated at point A in the attached pic. B shows beech marks where it propagated and C is the final failure. One interesting point is that the blades we can see appear to have failed in a very consistent manner. The final failure is roughly half the original cross-sectional area, indicating they are normally run at about 50% of their strength. It is true that the final failure is in the reverse direction but this could just be coincidence as that was the load state at the time when stress > strength. It was going to fail soon whether in forward or reverse.
    My best guess is that all blades had fatigued for some time due to extended surfacing and/or material deficiencies and/or stress riser due to machining. A hardness check could rule out one of those and a microscope could rule out another.
    Attached Thumbnails Attached Thumbnails 895562C3-208C-4929-AADD-19AE1186A02A.jpeg
  15. Likes John S, JBS liked this post
  16. #12
    Pekin, IL
    Quote Originally Posted by Whaaaaat View Post
    Definitely sharks!
    You guys been watching Discovery channel. It's shark week.
    Rock
    Team Junk
  17. Likes kellytheaker, powerabout liked this post
  18. #13
    MIAMI FLORIDA
    Also looks like they cut the hub maybe they nicked the blades all in the same area with the lathe... def started in the smooth almost cut looking areas at the trailing edge.
  19. #14
    May 2016
    keys
    Armor plated manatees out for revenge?
  20. Likes XstreamVking, powerabout, JR IN JAX liked this post
  21. #15
    The blades fell off?
  22. Likes kellytheaker liked this post
  1. So this happened............
    By rjdubiel in forum General Boating Discussion
    Last Post: 08-27-2019, 07:41 AM
  2. What happened to my gel?
    By Boz in forum Fiberglass and Composites Discussion
    Last Post: 10-15-2009, 05:30 PM
  3. What happened to the What happened thread?
    By in forum General Boating Discussion
    Last Post: 03-02-2002, 02:52 PM
