Results 1 to 7 of 7
    Jul 2018
    CORPUS CHRISTI TX
    Crankshaft Balancing
    Hey Guys,,,does anyone do crankshaft balancing or is that something thats only done @ the factory?
    Dec 2001
    This is how I do it..... my wife gets mad at me......
    https://www.youtube.com/watch?v=vROdVsU_K80
  3. Likes rock liked this post
    Quote Originally Posted by michaelogden View Post
    I wasn't aware that any outboard factory balanced their crankshafts ..
    The "factory balance" will jump out of the blocks and hit the floor ..
    Mercury could learn from Maytag ...
    Oct 2010
    Harrisburg,Pa
    Monty racing does them.
  6. Thanks michaelogden thanked for this post
    Oct 2010
    Harrisburg,Pa
    Still posting smart ass posts I see chaz nice job, Quite helpful.
    Dec 2001
    Don't ya wish Mercs could take such a beatin'..........
    Quote Originally Posted by perfmarine1 View Post
    Still sore I didn't post pitchers of "the witch's nose" modification on a sporty ... ???
    I'll say it again , I didn't invent it , so I'm not free to blab it .. perhaps that's why people trust me with their intellectual property ..
    Crank balancing ....
    Been discussed here before , maybe you should have spent half as much time using the search function as it took you to whine about the washing machine ..
    OP .. You wont find many shops that have bobweight's that will fit a 1.000" rod journal , you'll need to bring your own adapters and light weights .. the big washers won't be needed.
    A 120* crank for the most part is neutral , and can be dynamic balanced. I can tell you that a stock crank will jump out of the blocks and hit the floor .. it's as bad as that washing machine .. so no smart azz comment , just fact ..
    However , if you wish to deal with the end to end or secondary amplitude , you will need to build weights and spin it up.
    Hines recommends 30 to 50 percent .. I have always done outboards like Big Block Chevy's .. and went 52 percent .
    https://www.hinesindustries.com/imag...procalmass.pdf
  10. Likes keefallan liked this post
  1. Yamaha Tech: Crankshaft Balancing
    By LINKS in forum Technical Discussion
    Last Post: 03-02-2021, 09:39 AM
  2. crankshaft balancing
    By team fountain in forum Technical Discussion
    Last Post: 08-20-2011, 12:43 AM
  3. OMC crankshaft balancing(you there AL)
    By Roddles in forum Technical Discussion
    Last Post: 08-15-2005, 01:55 AM
  4. balancing
    By david laser86 in forum Technical Discussion
    Last Post: 10-18-2004, 11:30 AM
  5. Balancing
    By XBuddawg in forum Technical Discussion
    Last Post: 01-02-2002, 09:13 PM
