Results 16 to 30 of 43
Thread: How thick is your floor?
06-20-2021, 07:50 PM #16
The Historic Photo Master
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
...i glass in 1/2'' aluminum that was tapped for fine thread hex-head seat bolts/washers. no problems...only solutions...
ADDvanced liked this post
06-20-2021, 09:13 PM #17
Yep
This is the boat that's built lighter than you would ever believe...
a Sunday stroll
06-20-2021, 09:50 PM #18
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
06-20-2021, 10:52 PM #19
1/2" marine ply. 1.5oz CSM on the underside, 2 layers 1.5oz CSM on the top. Floor is rock solid. Also has two stingers under it.
06-20-2021, 11:16 PM #20
06-21-2021, 03:08 PM #21
Guest
- Feb 2021
- Milwaukeeish
- 255
- 20
- 137
- 92
Interested in learning more about nida core.... but again... finding a supplier in the midwest is super challenging. Anybody know of any?
Total plastics can get me coosa, so that will happen.
06-21-2021, 03:16 PM #22
I’m using 1/2” coosa. Was going to leave the bottom bare and do a couple layers of csm on top with two stringers underneath
06-21-2021, 03:26 PM #23
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
...again...its not about the core...its all about the glass over & under the core that determines the strength of ANY panel. generally speaking, the core, any core, should never be considered for strength or stiffness of a project. the core, no matter what it is, is just along for the ride, so it should always be a light core material. this goes for decks, stringers, transoms...anything. it gets glassed up in the same manner as cellulose, only the finished job is superior. its less important what brand it is, than the fact that you just use it, rather than cellulose. i would buy what ever brand & vender is the cheapest & the easiest to get in your hands. if you have to take a road trip, so be it.
06-21-2021, 03:39 PM #24
Guest
- Feb 2021
- Milwaukeeish
- 255
- 20
- 137
- 92
That can't be true tho, because if moisture gets into a plywood floor, that fiberglass skin sure sinks and the floor acts soft.
The thing about nidacore is that the main surface is a synthetic non-woven fabric, which absorbs resin and forms a giant bonding surface.
I have called a few suppliers in the midwest, and none of them have anything like this; they will have a honeycomb panel with aluminum faces, or a recycled cardboard honeycomb panel (which would turn to mush if moisture even looked at it).
I cannot find anything that offers the weight advantages of a synthetic honeycomb that is finished with a surface that will adhere to resin.
06-21-2021, 03:48 PM #25
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
...use closed cell foam core...any brand you can get. all the world & national championship boats i've built were bagged, but when glassed in a standard fashion, the quality of the finished product is excellent, just very mildly heavier on resin content, which means nothing on a pleasure boat.
WavetoWave liked this post
06-21-2021, 04:36 PM #26
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
06-21-2021, 04:52 PM #27
The core has to have some compressive & shear strength.
https://netcomposites.com/guide/core-materials/
06-21-2021, 04:57 PM #282023 Progression 22 w/ 2015 Mercury 300XS. 2018 Kawasaki Ultra LX. 1968 Hustler Wildcat 14. 1985 Hydrostream Vegas XT. Gone but not forgotten: 1991 POS GW Invader. 1976 Donzi Hornet II. 1994 Formula 232 LS. 2001 Regal 2660. 1990 Formula 206 LS. 1992 Checkmate Pulse 186 w/ 2003 Mercury 200 EFI. Random assortment of jet skis.
06-21-2021, 05:43 PM #29
When I was revamping my Eliminator, I experimented with different thickness plywood, and found that 3/8" marine plywood with one layer of 1808 on both sides was extremely strong.
You could take the bare 3/8" plywood and put a square across two flat surfaces and it would snap in two when you would stand on it, but with 1808 on each side, I could put my (then) 200 lbs on it no problem. I took 3/4" plywood out and replaced it with the 3/8" plywood/1808 combo, and it's strong. There's also bulkheads every two feet, and the stringers reach the floor, so the spans are very small as well.
If I was doing it again, I'd probably spend the coin and do 1" foam with 1808 on both sides, probably make a plate with studs hollowed out in the middle, router a spot for it in the bottom of the foam, and glass it all up. I've spent some time rigging in a 47 Outerlimits and it's amazing how much foam is in those things, and there's a reason they're as light as they are, but still take the waves. The floor was 1" foam in there, and it's an older boat. No issues that I could see.A problem is only a problem when viewed as a problem...
06-21-2021, 05:56 PM #30
So a layer of 1708 underneath I guess is now the plan. Think I need a second layer on top? Followed by csm?
How thick is your hull really ??
By tunnels in forum Fiberglass and Composites DiscussionReplies: 25Last Post: 11-30-2016, 05:53 PM -
Redoing floor/ drop floor
By gmjim in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 08-09-2013, 07:58 AM -
In floor heat and a in floor fish tank.
By JrCRXHF in forum The Scream And Fly LoungeReplies: 9Last Post: 01-08-2010, 01:33 PM -
Black thick oil????
By Vinnie in forum Technical DiscussionReplies: 4Last Post: 05-10-2008, 09:52 AM -
How thick is the hull?????
By MarkHP in forum Fiberglass and Composites DiscussionReplies: 1Last Post: 12-13-2003, 10:21 PM
