Results 16 to 30 of 43
    ...i glass in 1/2'' aluminum that was tapped for fine thread hex-head seat bolts/washers. no problems...only solutions...
  2. Likes ADDvanced liked this post
  3. #17
    PARADISE /Naples
    Yep
    This is the boat that's built lighter than you would ever believe...
    a Sunday stroll
  4. #18
    Minneapolis MN
    1/2" marine ply. 1.5oz CSM on the underside, 2 layers 1.5oz CSM on the top. Floor is rock solid. Also has two stingers under it.
  6. Likes ADDvanced liked this post
  7. #20
    Quote Originally Posted by Pulse186 View Post
    A flexy floor to save 30 pounds or a solid floor to not save 30 pounds, personally I don't think the boat will be faster or slower either way. But I plan on buying an aluminum anchor and a manual set back jack to save weight on my progression so what do I know, lol!
    I already ditched the jackplate, built a carbon fiber ski pylon, bought an aluminum anchor, lightweight gas tank and 4# lithium batteries. I would give your left nut to save 30#.
  8. Likes ADDvanced liked this post
  9. #21
    Feb 2021
    Milwaukeeish
    Interested in learning more about nida core.... but again... finding a supplier in the midwest is super challenging. Anybody know of any?
    Total plastics can get me coosa, so that will happen.
  10. #22
    Jun 2018
    Floating around
    I’m using 1/2” coosa. Was going to leave the bottom bare and do a couple layers of csm on top with two stringers underneath
  11. #23
    ...again...its not about the core...its all about the glass over & under the core that determines the strength of ANY panel. generally speaking, the core, any core, should never be considered for strength or stiffness of a project. the core, no matter what it is, is just along for the ride, so it should always be a light core material. this goes for decks, stringers, transoms...anything. it gets glassed up in the same manner as cellulose, only the finished job is superior. its less important what brand it is, than the fact that you just use it, rather than cellulose. i would buy what ever brand & vender is the cheapest & the easiest to get in your hands. if you have to take a road trip, so be it.
  12. Likes HydroSkreamin, MattGreen, WavetoWave liked this post
  13. #24
    Feb 2021
    Milwaukeeish
    That can't be true tho, because if moisture gets into a plywood floor, that fiberglass skin sure sinks and the floor acts soft.
    The thing about nidacore is that the main surface is a synthetic non-woven fabric, which absorbs resin and forms a giant bonding surface.
    I have called a few suppliers in the midwest, and none of them have anything like this; they will have a honeycomb panel with aluminum faces, or a recycled cardboard honeycomb panel (which would turn to mush if moisture even looked at it).
    I cannot find anything that offers the weight advantages of a synthetic honeycomb that is finished with a surface that will adhere to resin.
  14. #25
    ...use closed cell foam core...any brand you can get. all the world & national championship boats i've built were bagged, but when glassed in a standard fashion, the quality of the finished product is excellent, just very mildly heavier on resin content, which means nothing on a pleasure boat.
  15. Likes WavetoWave liked this post
  16. #26
    Quote Originally Posted by ADDvanced View Post
    ...i have'nt used plyrot for coring in a floor panel in 25 years...i'll take your word for it...
  17. Likes ADDvanced, WavetoWave liked this post
  18. #27
    The core has to have some compressive & shear strength.
    https://netcomposites.com/guide/core-materials/
  19. #28
    Nov 2019
    MI
    Not even that, what about a transom and stingers. If the wood rots they are toast. The entire structure has to be engineered from the get go where the glass is the structure and the core only the initial support. That obviously isn't done on smaller boats like ours.
    2023 Progression 22 w/ 2015 Mercury 300XS. 2018 Kawasaki Ultra LX. 1968 Hustler Wildcat 14. 1985 Hydrostream Vegas XT. Gone but not forgotten: 1991 POS GW Invader. 1976 Donzi Hornet II. 1994 Formula 232 LS. 2001 Regal 2660. 1990 Formula 206 LS. 1992 Checkmate Pulse 186 w/ 2003 Mercury 200 EFI. Random assortment of jet skis.
  20. #29
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    When I was revamping my Eliminator, I experimented with different thickness plywood, and found that 3/8" marine plywood with one layer of 1808 on both sides was extremely strong.
    You could take the bare 3/8" plywood and put a square across two flat surfaces and it would snap in two when you would stand on it, but with 1808 on each side, I could put my (then) 200 lbs on it no problem. I took 3/4" plywood out and replaced it with the 3/8" plywood/1808 combo, and it's strong. There's also bulkheads every two feet, and the stringers reach the floor, so the spans are very small as well.
    If I was doing it again, I'd probably spend the coin and do 1" foam with 1808 on both sides, probably make a plate with studs hollowed out in the middle, router a spot for it in the bottom of the foam, and glass it all up. I've spent some time rigging in a 47 Outerlimits and it's amazing how much foam is in those things, and there's a reason they're as light as they are, but still take the waves. The floor was 1" foam in there, and it's an older boat. No issues that I could see.
    A problem is only a problem when viewed as a problem...
  21. Likes ADDvanced liked this post
  22. #30
    Jun 2018
    Floating around
    So a layer of 1708 underneath I guess is now the plan. Think I need a second layer on top? Followed by csm?
  1. How thick is your hull really ??
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 11-30-2016, 05:53 PM
  2. Redoing floor/ drop floor
    By gmjim in forum Fiberglass and Composites Discussion
    Last Post: 08-09-2013, 07:58 AM
  3. In floor heat and a in floor fish tank.
    By JrCRXHF in forum The Scream And Fly Lounge
    Last Post: 01-08-2010, 01:33 PM
  4. Black thick oil????
    By Vinnie in forum Technical Discussion
    Last Post: 05-10-2008, 09:52 AM
  5. How thick is the hull?????
    By MarkHP in forum Fiberglass and Composites Discussion
    Last Post: 12-13-2003, 10:21 PM
