Results 1 to 6 of 6
Thread: Nmea 2k
    Maine
    Nmea 2k
    Has anyone found a way to convert an analog tach signal to NMEA2k? I see they have a water pressure sensor, and a temp sensor... The tach would be the last key to removing all gauges and flushing a HDS9 in the dash..
    Or has this proven not possible?!
    Jan 2003
    aalsmeer
    Quote Originally Posted by SkywayGT View Post
    You mean something like thisĺ?
    https://www.albacombi.com/product/al...000-converter/
  3. Likes 25two.stroke liked this post
    Maine
    My only issue with that setup is, im only using 1 motor, so the dual mota setup would be a waste.. I found the PC11 box from Noland, which will do it.. but was looking more along the lines of an arduino as the a/d convertor.
    Quote Originally Posted by PanRonnie View Post
    Ft. Lauderdale, Fl
    Maretron, but I don't know if they have something that will work on an outboard tach signal. I put one in a boat with an analog Yanmar without their display, just using a Garmin.
  6. Thanks SkywayGT thanked for this post
    Nov 2019
    Canada
    Could you do a smartcraft installation? That would work well. Might be a way of integrating with the Lowrance from there.
    www.InjectorService.com
    Call/Text - 204-326-0390
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by InjectorService View Post
    In my opinion it would be kinda pointless to do a smart-craft install on a carb merc v6. I've toyed with the idea of doing to a 260 or 280...upgrading all the sensors and such...but I don't think its worth it on a low hp one. And even on higher hp, why not just go all independent senders to a data logger at that point. I have messed with the misc. analogue to nmea 2000 sensors to integrate stuff on my boat with my Garmins and Smartcraft, they work real well. But as you said they have all the basic stuff like temp senders, fluid level, pressure etc. for not that expensive, but no one makes an independent analogue tach to nmea 2000 sender. Maybe its time to make one...
  1. Water pressure and trim data to nmea 2000.
    By CodeRed225 in forum Electronics, Audio Systems, and Wiring
    Last Post: 05-31-2021, 09:32 PM
  2. Mercury Smartcraft NMEA 2000 Gateway NAVMAN
    By 2.5-21 in forum Misc. Parts and Accessories
    Last Post: 03-03-2019, 07:01 PM
  3. SmaartCraft NMEA 2000 Gateway
    By 2.5-21 in forum Parts Wanted
    Last Post: 12-10-2017, 12:10 PM
  4. Vesselview Race Edition to NMEA 2000 network
    By pantera24-650hp in forum Electronics, Audio Systems, and Wiring
    Last Post: 05-14-2016, 06:18 PM
