Results 1 to 8 of 8
    Sep 2006
    Is it possible to bench test a water cooled 40 regulator
    Are there any bench tests to see if a 40 amp (88-90)water cooled is good or at least possibly good?
    Thx
    Houston, TX
    Do you have a manual? By the way, when they fail, the volts go high and they catch on literal fire. Want to know how I know that???
  3. Likes Capt.Insane-o liked this post
    Sep 2006
    I do, but have not found any tests for it
    Cleveland/Marblehead OH
    Get rid of that old POS, I can't believe one of those things are still around
    Sold the Skater, missing it everyday
  6. Likes David - WI, Capt.Insane-o liked this post
    Bin it unless you like smoke and flames. Promarine sells a conversion kit.
  8. Thanks coffeeguy thanked for this post
    Houston, TX
    I honestly replaced that POS with a pair of ones for a Pro Max run in parallel. Been working great for 3 years. I used a pair of 20 amps.
  10. Thanks coffeeguy thanked for this post
  11. #7
    Sep 2006
    It is for some ones back up motor, just don't want to give them one of these pos to install and see they are nfg.
    Thx for confirming what I thought about them.
  12. #8
    Houston, TX
    mine LITERALLY caught on fire (!!!!!!!) under my cowl and kept reigniting after a fire extinguisher until I disconnected my batteries. Could have been BAD. You might consider pitching it in the trash just to avoid the above for someone else. Scary AF!
  1. 40 amp water cooled regulator
    By kingsbiship in forum Misc. Parts and Accessories
    Last Post: 11-28-2018, 09:18 PM
  2. Water cooled regulator
    By j_martin in forum Technical Discussion
    Last Post: 08-29-2008, 07:40 AM
