Page 10 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 136 to 150 of 166
  1. #136
    I'd like a 4 inch core because I'm thinking ahead. The next owner may want to put a pair of V8 motors weighing in at 500 lbs each (if that) I'd like this transom to be ready
    the double thickness transom core also fits in 1 sheet of 4x8x2 coosa, so why not use it
    here is a mockup of 4 inches of coosa core ..dang !
  2. Likes tnelsmn liked this post
  3. #137
  4. Likes mrichartz, 89LASER, tnelsmn liked this post
  5. #138
    PARADISE /Naples
  6. Likes noli liked this post
  7. #139
    I would not mix epoxy and vinyl. I know some do it but not me. As far as trans thickness, I have a 3'' transom in all my boats. 4'' is Heavy duty.
  8. Likes noli liked this post
  9. #140
    PARADISE /Naples
    Vinyl and epoxy are cousins in the chemical world
    Vinyl ester is great stuff in every way shape and form, It breaks loose the binder in mat making things move around where epoxy it will stay stiff.
  10. Likes noli liked this post
  11. #141
    getting the transom clamps ready
  12. Likes tnelsmn liked this post
  13. #142
  14. Likes tnelsmn liked this post
  15. #143
  16. Likes tnelsmn liked this post
  17. #144
    cutting the coosa board from transom template
  18. #145
  19. #146
    1st cut from a 2 inch coosa board
  20. #147
    2nd cut shall make it 4 inches + laminates = 4.5 inch transom
  21. Likes XstreamVking liked this post
  22. #148
    first fitting of new transom
    ...needs adjustment
  23. #149
    I guess you know to rough that stuff up good and wet it well before install?
  24. Thanks noli thanked for this post
  25. #150
    compression tool for the installation of the coosa composite transom
