Results 1 to 15 of 22
    Feb 2021
    Milwaukeeish
    8' 3 Point Hydroplane, Mini Max Sea Flea Project! Goal: 50mph with 10hp lolz
    Thanks for the answers in the previous thread, this thread will be my build and adventures in it! I put together a quick video showing the boat, my plans for it, and what it needs before it hits the water. Cheers and enjoy!
  2. Likes 89LASER liked this post
    Feb 2021
    Milwaukeeish
    On the fence between redoing the hull coating with polyester resin, vs epoxy. I know epoxy is more durable but I hear it's less flexible, but on the other hand how much flex can an 8' hull even have. Started sanding today, and rebuilding the front steering wheel support. Picking up motor this weekend.
    Aug 2018
    To far away from the lake
    Quote Originally Posted by ADDvanced View Post
    It's a +30 ? yr old kit boat that's going to be bouncing all over the water (again). It's going to flex. The success of your overlay will depend heavily on your prep.
    Feb 2021
    Milwaukeeish
    Heat gun and putty knife at lunch break, made a ton of progress. Then going to sand it, get it wet to raise wood fibers, and sand again. I have epoxy so I think I'm going to try it.
  6. Likes JR IN JAX liked this post
    Aug 2019
    Palmharbor
    Was at Dons Salvage last week he had a solid kekif 18 hp wizard compleat
    Feb 2021
    Milwaukeeish
    Started the heat gun/putty knife scraping during the lunch hour yesterday, and then worked from 6-9 and have the whole thing pretty much scraped. Next step is clean it off and go over it with a fine toothed comb to make sure I didn't miss any little chunks, then wood filler on any gouges, then sanding, then epoxy. I think.
  9. Likes Mugs914 liked this post
    11 Post(s)
    Use polyester resin and save yourself a couple hundred bucks.
    Thin it 10% with acetone so it will penetrate the wood and stick better.
    It will do everything you want it to do and more.
    Unless you’re going to leave it in the water for the season, even that is overboard.
    And adds unnecessary weight to an 8 foot boat!
    Alternative is get it to bare Wood then thin down some good pettit varnish, fill the grain, make it look good, clamp a motor on and call it a day.
    On an 8’ boat/hydroplane, it’s all about weight.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Feb 2021
    Milwaukeeish
    Thought about it, but I've never used epoxy before so I'm sort of using this as a test bed. Also going to try graphite powder and epoxy to reduce drag.
    PARADISE /Naples
    Aug 2018
    Just having fun here.....You might have better results with a clean shave and wearing a swimming cap before that top speed run.
  14. Likes Instigator, KIRCHNER, capteliminator liked this post
    Feb 2021
    Milwaukeeish
    lmao. Hey this should be pretty quick with the engine I have for it. We will see. Maybe it'll only do 35 and be a massive fail.
  16. #12
    Lake Coochiching, Ontario
    I doubt if my old 8’ hydro w/20 Chrysler went 35 mph but it was massive fun at the time. 70’s
  17. Likes Instigator liked this post
  18. #13
    Feb 2021
    Milwaukeeish
    Updates:
    Finished stripping the hull, sanded it down, and here is the first coat of ProMarine Epoxy:
    Here is the second coat:
    It's not super warm here, maybe 65 tops, and 50s at night, so even with the fast hardener it's taking quite long to setup, but it is working. The first two coats were done front to back, but I kept getting lines of the plywood that were avoiding the epoxy, so I did a third coat side to side, in an attempt to fill in the ridges. It helped a lot, but I didn't get all of it, so I did a fourth coat side to side as well.
    I am thinking I will do a 5th coat in a few hours, front to back, and that will most likely be the the final coat. Then it's time for leveling/sanding. Also, I used some extra epoxy from the fourth coat to mix up some of the graphite infused epoxy, and threw it on some scrap wood. Interested to see how it turns out.
  19. #14
    Feb 2021
    Milwaukeeish
    Episode 2 just dropped, enjoy and lmk if you have any feedback:
  20. #15
    North Tonawanda, NY
    Back in the 1960s as a teenager I had a 1950s vintage Speedliner Class A-B utility running a stock Merc KG-7 with a cut-off lower unit tail to open the exhaust to above water. Running stock merc aluminum props I managed to just hit 40 mph. I sold the motor to a fellow who had a Class A 3 point hydro- again an old 1950s race boat which appeared to be a homebuilt from Hal Kelly's plans. He managed to get 45 mph out of it, again with stock Merc props. We raced once for top end just for kicks- I had bought a stock Mark 25 Merc to replace the KG-7 and I was running a Michigan AJC series 2 blade aluminum prop. Our top ends were just about equal- 45 mph with maybe an extra 1/2 mph for my rig. I remember my old kneel down boats every time I look at the scar on my left knee from the replacement surgery I had at age 67.....
    Doug
  21. Likes ADDvanced liked this post
  1. Will a 10HP get a Voo Doo Mini up on plane?
    By chameleongates in forum The Scream And Fly Lounge
    Last Post: 02-23-2013, 07:29 AM
  2. Compresson goal?
    By Techno in forum Technical Discussion
    Last Post: 04-22-2004, 07:02 PM
  3. 13 mini hawk 25 merc project..(amature)
    By baja200merk in forum Technical Discussion
    Last Post: 03-23-2004, 03:31 PM
  4. Project CVX mini-update
    By tombrown in forum General Boating Discussion
    Last Post: 06-25-2002, 11:15 AM
