Page 9 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 121 to 135 of 166
  1. #121
    took a wooden wedge and removed the delamination on the transom
  2. #122
  3. #123
    done removing
  4. #124
  5. #125
  6. #126
    cleaning up the tunnel-to-transom corner
  7. Likes mrichartz, tnelsmn liked this post
  8. #127
    I saw early in the thread you are going with a single engine. Cats don't like a single in the middle. Might want to consider twins even of they are smaller....like 150's.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  9. Thanks noli thanked for this post
    Likes noli liked this post
  10. #128
    started the transom template
    I will be refining it so that both port and stbd sides are close to being equivalent
  11. Likes Aaronhl liked this post
  12. #129
  13. #130
  14. Likes tnelsmn liked this post
  15. #131
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Go to HD or Lowes and get a sheet of luan. Rip it down to 2 or 3" strips. Makes great template material.
    1996 Checkmate Pulsare 2100 with a 2017 Merc 250 Pro XS
  16. Thanks noli thanked for this post
  17. #132
    Thanks for the tip, I'll do that when I do my other wreck..a 20 foot Hydrostream
    This template is almost done. I'll be making a few adjustments to this strip template then I'll transfer this shape to a 1/4 inch plywood before I transpose once more to my coosa board
  18. #133
    PARADISE /Naples
    I believe 4 inch transom is over kill, what ever you use I would put some mat between them and install as one, a bunch of C clamps would be nice, mat is your friend for adhesion Vinyl Ester is a must, it is truly water proof and better adhesion.
  19. Thanks noli thanked for this post
  20. #134
    I was thinking epoxy as the resin between the coosa and the transom skin and the middle layer, between the 2 coosa boards
    then Vinyl Ester resin to cover the coosa's externally exposed sides
    very rough cut of the template. It will be sanded and straightened and rounded
  21. #135
