Results 16 to 30 of 44
Thread: Hyd steering slop
04-30-2021, 07:32 AM #16
Member
- Apr 2011
- WI
- 42
Im not 100% but I think it may be one of the fittings or it could be the end of the hose.
After work today I will go down there again and clean it and try to find the leak, I think I have the right orings at home.
If I remember correctly the Quicksilver/Merc system uses ORFS fittings. (oring face seals)
This is one of those situations where even if its right my brain still wont accept it.
2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
2014 Checkmate 2000 Pulsare BRX Merc 250 Pro XS
Powerquest 290 Enticer FX Twin 454 Sold
Hand Built 10ft Aluminum Jet Boat 1500cc Kawi 4stroke Sold
Playcraft 24ft Tritoon conversion with 235 GT Johnson Sold
04-30-2021, 07:56 AM #17
Member
- Apr 2011
- WI
- 42
04-30-2021, 08:41 AM #18
5000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Those plastic plugs don't seem right? I don't use seastar so not familiar with there setup, but I wouldn't have plastic port plugs in anything under pressure. That needs metal.
ANTI40It's just an idea.
David - WI liked this post
04-30-2021, 09:02 AM #19
Member
- Apr 2011
- WI
- 42
04-30-2021, 10:36 AM #20
Screaming And Flying!
- 15,130
- 415
- 1478
- 6103
- 11792
You can see fluid in the 1st pic on the fitting with the white mark, right at the connection to the hose.
04-30-2021, 11:07 AM #21
Junior Member
- Feb 2020
- Finland Kotka
- 9
provides leakage hose and connector connection. plastic connectors last yes. glue to each joint. degreasing brake cleaner
04-30-2021, 12:56 PM #22
Member
- Jan 2019
- Ontario, Canada
- 38
- 7
- 11
This is just a FYI for SeaStar systems, I had similar issues with my Sea Star, had to put the boat severe nose down and tech guy said turn the wheel to the stops and crank on the wheel farther for a turn, and pop the reliefs. Makes a nasty noise. got more air out. Not sure if that will apply to you but might help SeaStar owners out.
04-30-2021, 07:44 PM #23
Member
- Apr 2011
- WI
- 42
I found my spare ORFS seals, from 2 boats ago. I will go down to the boat tomorrow replace seals on hoses at helm and do a thorough bleed and will try to over power the relief valves.
I wonder if the previous owner ran the helm low on fluid and caused some wear in it. There is no way this steering should be such an issue.
Ive done 2 scratch installs and both have turned out amazing.
Thanks for the tips everyone.2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
05-02-2021, 08:33 PM #24'78 Hydrostream Viking/'98 225 ProMax
05-02-2021, 08:55 PM #25
Member
- Jan 2019
- Ontario, Canada
- 38
- 7
- 11
Glad that worked for you!
05-03-2021, 05:57 AM #26
- 15,130
- 415
- 1478
- 6103
- 11792
Sometimes removing the cylinder from the engine allows full stroke of the cylinder it couldn't get when attached. Depends on the application. I bleed mine before install, since you can raise the cyl up high and get full stroke. jm2cts
05-03-2021, 07:23 AM #27
Member
- Apr 2011
- WI
- 42
Looks like the fluid is coming from top port with plastic plug. Im thinking a relief valve is weak/worn causing my issues.
Dealer is getting me a new helm pump then I will try everything suggested to bleed this out. I think the helm pump has been my issue the whole time.2019 Crestliner 240 Rally DX CWDH Tritoon Merc 200 DTS
05-03-2021, 07:46 AM #28
5000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Plastic plugs in the garbage can. Then just have your dealer hook it to there power bleeder. Power bleeder takes 10 minutes.
05-03-2021, 07:47 AM #29
Member
- Jan 2019
- Ontario, Canada
- 38
- 7
- 11
Just guessing but is that a helm pump for dual helms??
05-03-2021, 08:01 AM #30
Member
- Jan 2019
- Ontario, Canada
- 38
- 7
- 11
Just FYI on steering pressures, when my boat wouldn't like to turn right the dealer was calling me an idiot. Ok, Gauges it is, over 1500 psi at the steering cylinder to turn the boat right and only 5-600 to turn left. Now on shore I am putting my 75 lb fish scale on the steering wheel and put the engine full lock right and tried to pull 1500psi. The scale wasn't big enough. Think my wife can pull 80lbs to turn the boat??
Hydro steering...how much slop should it have?
By rgsauger in forum Technical DiscussionReplies: 8Last Post: 06-23-2020, 03:58 PM -
steering slop
By David in forum Technical DiscussionReplies: 10Last Post: 07-17-2012, 07:08 PM -
Slop in hydraulic steering?? Litle help please
By bill mason in forum Technical DiscussionReplies: 14Last Post: 07-22-2009, 08:08 AM -
how to tighten slop in lower end of steering arm?
By silverbullet02 in forum Technical DiscussionReplies: 4Last Post: 02-08-2008, 08:49 PM -
Steering slop
By 83PREDICTOR in forum Props, Setup, and RiggingReplies: 2Last Post: 01-13-2008, 07:05 PM
