Results 16 to 29 of 29
Thread: 2.4 switchboxes keep going bad.
07-15-2009, 06:54 PM #16
ok thanks or all the replies! i have been told twice today that you can burn up switch boxes by cranking on a low battery????? i have done this tooooo many times
07-15-2009, 10:24 PM #17
07-16-2009, 01:58 AM #18
switch boxs
Does this engine have an idle stabalizer/spark advance box fitted. If so disconnect and/or discard it. This could be causing the repeated switch box failure.Also, these boxs have been known to detonate pistons through over advanceing ignition timing.Popey
Popey
04-17-2021, 03:24 PM #19
5000 RPM
- Dec 2017
- sam rayburn lake...east texas
- 184
- 14
- 13
I have two switchbox's testing at 1410 and 1413 would this be a problem little over cdi testing specks of 1400 eBay boxes
04-17-2021, 06:03 PM #20
Fwiw. If u replaced 3 then u not replacing them in pairs and ur chasing ur tail. Get 2 new Sierra boxes also need check conditions of wire from stator and trigger. If hard and brittle and missing pieces, should b replaced
04-17-2021, 06:05 PM #21
You need to check to see if your getting any voltage to the black and yellow wires when you cycle the key switch.
04-19-2021, 06:20 AM #22
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,353
- 10
- 266
- 32
- 734
[QUOTE=Capt.Insane-o;3276622]You need to check to see if your getting any voltage to the black and yellow wires when you cycle the key switch.[/QUOTE
Yes!!! ,anything over .4 volts on the kill circuit,at any time...on off cranking or priming can destroy the switchboxes.Brass throwoff inside the back of the keyswitch from arcing builds up over time and becomes a semi-conductor dust...worse when you add dew or rain,Chris
rgsauger thanked for this post
04-20-2021, 05:13 AM #23
5000 RPM
- Dec 2017
- 184
- 14
- 13
04-20-2021, 10:53 AM #24
Aircraft quality toggle switches
25two.stroke liked this post
04-20-2021, 10:59 AM #25
Screaming And Flying!
- 15,137
- 416
- 1478
- 6114
- 11808
Here's some American made stuff...https://www.sherco-auto.com/battery-...-switches.html
04-20-2021, 04:37 PM #26
5000 RPM
- Dec 2017
- 184
- 14
- 13
my black yellow tested zero 0 with key off at the box
04-21-2021, 05:56 AM #27
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,353
- 10
- 266
- 32
- 734
XstreamVking liked this post
04-21-2021, 10:10 AM #28
5000 RPM
- Dec 2017
- 184
- 14
- 13
OK thanks...... I'm running your reeds and stuffers in a 1991 14 pedal motor best move I have made big improvement in power top and bottom RPM
05-20-2021, 06:31 PM #29
5000 RPM
- Dec 2017
- 184
- 14
- 13
I have a 10 wire key switch that's no longer available if I need to cut the wire to put it on a switch will it be the black/yellow wire that run to the two switch boxes its on the key switch and its not a hot wire it must be a ground ??????????????
