Page 9 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 121 to 135 of 250
  1. #121
    Nov 2003
    Portsmouth VA
    I used a long narrow 12gal tank laid between the inner stringers, centered between the seat box and the front of the splashwell. THis balanced the boat very well.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  2. #122
    May 2020
ID:	485473Click image for larger version.
    Quote Originally Posted by 99fxst99 View Post
    I’m using a 18gal tank that will be hidden behind the rear seat, the seat will be hinged so I can access everything behind it.
  3. Likes tnelsmn, 99fxst99 liked this post
  4. #123
    May 2020
    So as I get closer to having the entire inside of my boat completely covered in a layer of 1708 what should be the finished layer? Should I cover all the 1708 with a layer of csm for the finish or should I roll on more epoxy to smooth our the mat, I have a bunch of csm left over. I’m undecided if I will paint or gel coat the interior but what ever I do I’m going to give it that splattered look like a lot of guys are doing to give it a texture (grippy) effect. Also will gel coat even work over epoxy?
  5. #124
    I would think either would be fine.
    Minneapolis MN
    I would add CSM to smooth out the 1708. Gelcoat won't work over epoxy. You'll have to find a different solution. Awl-grip, etc.
  7. #126
    May 2020
    Quote Originally Posted by tnelsmn View Post
    Why is it that gel won’t work over epoxy? The one thing I wanted to gel for sure was the running surface of the boat but first I have to fix all the gouges and and straighten all the strakes and pad. I guess I shouldn’t use any epoxy for this if I’m gonna gel coat it. I could paint the running surface I suppose... the boat will never sit in the water for more than 8hrs at a time. I figured gel on the bottom would be more durable for driving on the trailer and sand bar beaching. If you look back at pics of my boat it is two tone red and white, my plan is to keep it white on the bottom like it already is then paint the red a metallic battleship grey.
  8. #127
    There's a big debate on this, but polyester over epoxy can have compatibility issues. Some want a barrier coat over the epoxy. West says it's ok over fully cured epoxy but the trick is to figure out when the epoxy has cured enough.
    In any case, epoxy is always tougher than gel coat. The first penetration of the core in my boat was at the front of the V where it actually wore through from beaching. I repaired it much thicker than the original and some years later added an epoxy based "rash guard" just to be on the safe side.
    Unless you're doing a show boat type restoration, mixing epoxy with thickener and white pigment will work fine to fill the gouges. I used cabosil as a thickener but that can be hard to sand.
    May 2020
    yes the epoxy is some serious stuff, I have drips of it on the old dirty gel and you ain’t getting it off unless you chisel or grind it off. I also have drips on my polished concrete floor and it ain’t coming off, the epoxy will cure rock hard in a bucket of water.
  10. #129
    May 2020
ID:	485621 Final Layer of 1708 went over my floor tonight, also tabbed in the back side of my rear seat toe kick. I drilled oversized drain holes in my bulkhead, seat box and toe kick, then I filled them back in with thickened epoxy and glassed a small piece of 1708 over the holes, when it hardens I’ll drill them back out with a smaller bit that way no chance moisture will be able to get to the wood. A little overkill I guess...
  11. Likes tnelsmn liked this post
  12. #130
    May 2020
    Front bulkhead is complete, tabbed in, one layer of 1708 and a layer of csm. Worked on the splashwell delete also, thickened epoxy around the perimeter followed by one layer of 1708. Calling it a day.Click image for larger version.
  13. Likes tnelsmn liked this post
  14. #131
    May 2020
    Oh yeah, also put a layer of 1708 on the underside of my seat box lid before I close it up.Click image for larger version.
  15. Likes tnelsmn liked this post
  16. #132
    May 2020
    Got a layer of csm down from the bulkhead to the front of the seat box. Also the seat box lid is permanently on now along with 3/8” t-nuts and bolts. Next is to glass the seat box and continue with csm to the back of the boat.Click image for larger version.
  17. Likes LakeFever, tnelsmn liked this post
  18. #133
    May 2020
    What are you guys doing when it comes to protecting the hull number on the back of the boat when sanding and preparing the boat for a different paint color?
  19. #134
    May 2020
    First new part showed up for the boat today, now I can build my mounting block for it.Click image for larger version.
  20. Likes tnelsmn liked this post
  21. #135
    Nowthen, Minnesota
    Quote Originally Posted by Jmr1974 View Post
    Them T-Nuts should have went in from the bottom. They will pull out very easily from the top like that. Ask me how I know. LoL
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
