Results 1 to 7 of 7
    Aug 2020
    Abingdon Virginia
    Mercury 2.4 Oval Port 240 HP Powerhead
    2.4 Mercury Oval port Powerhead . Cylinder plating is in great shape with the original 3.337 bore. Simon alternator kit. Land and Sea heads. Mercury Digital 11350 ecu with the gold 39 lb. regulator. Engine runs very strong with 125lbs. compression across all 6 cylindersClick image for larger version.
ID:	483657Click image for larger version.
ID:	483656Click image for larger version.
ID:	483658Click image for larger version.
ID:	483659Click image for larger version.
ID:	483660Click image for larger version.
ID:	483661. Compression check certified by MTM Marine Bristol Tn. $3000.00 any questions feel free to call 276-608-0888 Thanks, Blaine
  2. Likes 25two.stroke, scott reierson liked this post
    Apr 2018
    grosse ile mi
    is this a bridgeport
    Jan 2020
    Pittsburg, Ca
    Quote Originally Posted by dragmirage View Post
    The notation that its a "ovalport" means that it is not a bridgeport. Its a finger/oval port block.
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    Apr 2020
    South Carolina
    Don't see too many of those!
    Aug 2020
    Abingdon Virginia
    Sold
    Jan 2020
    Pittsburg, Ca
    Heres another one just for pics! I got mine on the floor in the house too! I'm pushing 190psi cold, 56 psi reg and exhaust chest cut. Your motor looked great and glad you got it sold. 2.4 ovalports are great!!!
ID:	484548Click image for larger version.
ID:	484549Click image for larger version.
    Attached Thumbnails Attached Thumbnails 20201211_225751.jpg   20201211_231148.jpg
  8. Thanks Blackmotorsmatter thanked for this post
    Likes Blackmotorsmatter liked this post
    Dec 2004
    Lakeland, Fl.
    I owned one. Tons of power, reliable and "no cracked bridges". Someone got a good deal on a great little motor. JMO
    The impossible I do right away, miracles take a little longer.
  10. Thanks Blackmotorsmatter thanked for this post
  1. OMC 56 Oval port motor port specs
    By phillnjack in forum Technical Discussion
    Last Post: 09-02-2017, 10:34 AM
  2. Mercury 280 Oval Port Tuner
    By moomba in forum Misc. Parts and Accessories
    Last Post: 07-23-2013, 07:26 PM
