Results 16 to 30 of 36
    MIAMI FLORIDA
    The home brewed stuff is the coolest, nice work.
  2. Likes Instigator, dagodiver, V pads liked this post
  3. #17
    sw florida
ID:	484097Click image for larger version.
    Seems to fit just fine. Bit of transom work. Should be good.
    Dago.
  4. Likes Instigator liked this post
  5. #18
    11 Post(s)
    Yeah but you’ll have to change your hour meter to a minute meter.
    ...those black parts just simply touching those "other" parts, should be good for an additional 10 mph alone......
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. Likes LakeFever, keefallan liked this post
  7. #19
    ...nice work. did you do the mid shortening work?...
  8. #20
    ...bead blasted, or?... what media material?...
  9. #21
    sw florida
    LOL.!!
    Dago.
  10. Likes LakeFever liked this post
  11. #22
    sw florida
    FUJIMO,
    Yes I cut the mid. You can see it fixtured up in the first set of pics on the welding table.
    Its still just tacked together until I fit it all up. Im building a wing plate holder to go in/on the can also.
    Aluminum Oxide media in the blast cabinet. Its what I use to do all the gun barrel prep before Cerakote.
    Dago.
  12. Likes Capt.Insane-o liked this post
  13. #23
    11 Post(s)
    If you look at a Taylor mid, they have tabs cast into both sides for wing plate mounts.
    Id think you could do same.
    Fit a pc of 1/2” alum bar to the sides and just run a beed around it?
  14. Likes dagodiver liked this post
  15. #24
    sw florida
    Going to try and machine a plate recessed into the can that sticks out the sides to bolt the wings to that 6 of the engine studs pass thru.
    Trying to keep the welding to a minimum.
    Dago.
  16. Likes Instigator liked this post
  17. #25
    11 Post(s)
    Perfect!
    I like it.
    Quote Originally Posted by dagodiver View Post
    Dago.
  18. Likes dagodiver liked this post
  19. #26
    Dago.
    ...thats actually the same way bob latham designed his early standard merc v-6 plates many years ago. plate(s) bolted to plate(s). its the only way sometimes with stock/standard mids. agree with as little welding as possible, as it births weak points on cast stuff...
  20. Likes dagodiver liked this post
  21. #27
    ...no, your right...the rotating assembly part here isn't black, so the minute meter "would" be more apropos. ding ding ding...
  22. #28
    lol..
    I was glad to see that stuff put to good use. The up/down came from Australia via Italy.. So some of that has a history.
  23. Likes dagodiver liked this post
  24. #29
    11 Post(s)
    And will need wing nuts for head bolts.
  25. Likes dagodiver liked this post
  26. #30
    That is not true ..
    However you have to be just a little bit smarter than what your working with ..
  27. Likes dagodiver liked this post
  1. Build my intruder back or build a black motor..advice needed!
    By Twilliams4003 in forum General Boating Discussion
    Last Post: 01-05-2021, 07:56 AM
  2. 84 mercury mod vp first hi perf build
    By BoomerMuskoka in forum Technical Discussion
    Last Post: 12-02-2016, 04:34 AM
  3. Mercury 2.4 build
    By Small strokes in forum General Boating Discussion
    Last Post: 02-16-2016, 08:28 AM
  4. Mercury 2.5L 200hp Build Up
    By chubsta in forum Technical Discussion
    Last Post: 08-08-2002, 08:15 AM
