Page 19 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 LastLast
Results 271 to 285 of 438
  1. #271
    Sep 2012
    washington
    22 MTR Cougar
    Gaining on my motor swapClick image for larger version.
ID:	482835Click image for larger version.
  2. #272
    Aylesford Lake,NS Can.
    Let's See Your Cougars-Boats That Is!!!
    Quote Originally Posted by crescentbar View Post
    Tim
    Great job! it fits in there nicely. Will you have to modify the hatch for the new motor? Keep the photos coming. My friend is a collector of old gas pumps and other memorabilia and he would like some of the items you have in the background.
    Thanks
    Gary
  3. #273
    Quote Originally Posted by luv2gofast View Post
    Hi Gary,
    Thanks! It seemed like the right choice to use the LED indicators. On my Lavey I have mechanical so that's what I'm used to. The LED's of course have discreet steps as opposed to the smooth movement of the mechanical. That and the price would be the only complaints. They were much easier to rig because the trim signal is on the NMEA 2000 bus from the engines so all it took was a NMEA 2000 tap for the Lavorsi to get the trim info. The Lavorsi jack input is analog 0-5V but puts out the NMEA codes as trim 3 & 4 onto the bus. That gives me the ability to put them on the Lowrance as an overlay. I didn't end up using it. That was special programming that I had Livorsi do so they are versatile unites and all custom order. I went to great lengths to make a clean actuator for the morse cable on the Lavey with a ramp on the motor side of the jack plate and a roller that pushes the morse cable that comes through the transom. With the Cougar I made my own actuators also because I don't like morse cables for jacks and that was the only thing I could find for mechanical to electronic. I used bicycle cables which I found in stainless with stainless jackets. Both actuators were big projects but I think the are each better than anything available of-the-shelf. The first four pix are the Cougar and the last two are the Lavey.
    luv2gofast
    I just took another look at the photos of your actuators. WOW that was some truly custom work to make those and getting them set-up.
    Thanks for posting the photos
    Gary
  4. #274
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by Hydrogasm View Post
    luv2gofast
    Gary
    I love to do those kind of things on my toys. I couldn't live without a machine shop!
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  5. #275
    Sep 2015
    Enfield CT
    Any one have a trailer cover for a 21 MTR or know of anyone who has the patterns? I have people who can make one but prefer not having to take the boat somewhere if I don't have to.
    300R is going to be mounted in a few weeks.
  6. #276
    Quote Originally Posted by jsisson10 View Post
    jsisson10
    Here is the link to one that crescentbar had listed:
    21' MTR Cougar cover (screamandfly.com)
    Check it out.
    Good luck
    Gary
  7. #277
    Jan 2021
    salmon arm b.c.
    cougar dave (can)
    I thought I might add to the post started by Gary (Hydrogasm) “lets see your Cougar that is”. Attached photo could be called “lets see your Cougar that was”. This is as close as I can come to displaying the very first Cougar Tom made out of his garage in Duncan on Vancouver Island, almost to the day, 51 years ago. It is a 16 1/2 foot vee bottom called “THE SPRINT” I think it took him something like 2 weeks to just lay it up and yes it was built like a tank and about as heavy as one
    He and his wife moved to Salmon Arm in 1972 where he and I formed Cougar Custom Boats and over the years made something like 600 boats with one tunnel going as far as New Zealand to come back as an aluminum hulled 19' jet river racer and one even going to China??
    It has been fantastic to read and see all the boats in this post over the past year or so and see how many are still out there with some even going through restoration. I am sure TOM would be “proud as bunch” (English saying for Super Proud) to see all this and read the comments. He made one “hell of a boat” He retired to Mexico but we still keep in touch.
    Cougar Dave (Can)
    PS Try emailing me direct if there is anything I can help you with or if you would like a copy of the history of the company
  8. Thanks cougarken thanked for this post
  9. #278
    I am glad you finally decided to post on my thread and I hope you will share some of the info you gave to me with the rest of the members.
    Thanks
    Gary
  10. #279
    Sep 2012
    washington
    I have the exhaust and drive work finished up.Had to have the riser welded up to match the water ports and better flow the exhaust.(old style to new style Powerflow).I had bought a set of used risers(saved about 1500). The lower unit need some of its patina to go away.Also remove the front water pump and put a water pass over on.That saves about 50 pounds and a belt.Got lucky and did not have to modify the hatch(thanks Cougar boys)Just abut ready for a beat down on her,LOLClick image for larger version.
ID:	483840Click image for larger version.
ID:	483841Click image for larger version.
ID:	483842Click image for larger version.
  11. #280
    Tim
    You are coming right along. How long before you get it wet? Let us know.
    Thanks
    Gary
  12. #281
    I got my new Zeiger 7" tilt helm and Charlynn steering valve on Monday. What beautiful piece of workmanship. Thank you to Paul Everett at Everett Performance for his help in ordering it. I hope to get it installed today.
    Thanks
    Gary
  13. Likes HydroSkreamin liked this post
  14. #282
    Sep 2015
    Enfield CT
    300R Mounted! - Not just waiting for ice to clear
    I had the 300R bolted on yesterday. Very excited to see how she performs compared to the XS with DBR. Also put a bobs extreme action jack plate on it (very nice unit) and fixed a few imperfections in the floor. Little bit of wiring, install the interior, ceramic coat and then just wait for the ice to clear.
ID:	484111Click image for larger version.
ID:	484112Click image for larger version.
  15. Likes peterse90, luv2gofast, Speedicat liked this post
  16. #283
    Jul 2009
    gatineau qc, canada
    nice looking boat! on your 1st pic it looks like the skeg was cut and it threw me off! but clearly its the shade giving that illusion!
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
  17. #284
    That looks great on there but it seems very high in the air with the jack plate all the way up? How many inches about the pad are you? Keep us posted and thanks for posting the photos.
    Gary
  18. #285
    Sep 2015
    Enfield CT
    Gary
    Thanks im very happy with it. I had the plate all the way up for trailering. The xs ran about a half inch above the pad give or take. Never measured exactly cause i just went up with the plate till water pressure was at 9 lbs. Im told these run about an inch higher than the xs so that puts me at 1.5 in above the pad but we will see.
  1. How many guy's on here have 2004-2005 boats or have older boats ??
    By LPB in forum General Boating Discussion
    Last Post: 01-13-2018, 06:09 PM
  2. New mini performance boats? - St. Martin Power Boats
    By jonnyspeed in forum General Boating Discussion
    Last Post: 04-09-2009, 08:30 PM
  3. Bass and Walleye Boats Mag...Triton boats!
    By Mr.Rude in forum General Boating Discussion
    Last Post: 06-06-2006, 10:13 PM
  4. Triad Boats and STV Custom Race Boats
    By Dinomite in forum General Boating Discussion
    Last Post: 12-27-2003, 10:30 AM
