Results 3,316 to 3,330 of 4053
Thread: Fastest SOB hull???
03-07-2021, 08:49 AM #3316
03-07-2021, 10:56 AM #3317
03-07-2021, 11:13 AM #3318
5000 RPM
- Apr 2017
- Pomona ny
- 257
- 12
- 50
Love to see the numbers on the progression.
03-07-2021, 01:13 PM #3319
Supporting Member
- Jul 2004
- Connecticut
- 6,264
- 518
- 205
- 1074
- 1127
TooStroked liked this post
03-07-2021, 02:08 PM #3320
Supporting Member
- Jul 2004
- Connecticut
- 6,264
- 518
- 205
- 1074
- 1127
88mph with a 250R and 94mph with a 300XS for Progression's 22. 450R ?
At these higher speeds does 10hp still get you about 1mph or is it all in the set up. Time will tell.
03-07-2021, 03:46 PM #3321
5000 RPM
- Jan 2017
- Albany NY
- 400
- 28
- 20
- 99
- 126
03-07-2021, 04:46 PM #3322
03-07-2021, 05:35 PM #3323
Greg G thanked for this post
03-07-2021, 05:49 PM #3324
Grant Conklin liked this post
03-07-2021, 07:49 PM #3325
Member
- Sep 2010
- north battleford saskatchewan canada
- 59
- 7
03-07-2021, 09:37 PM #3326
03-08-2021, 06:24 AM #3327
5000 RPM
- Oct 2016
- Amityville, NY
- 197
- 30
- 13
- 84
- 140
03-08-2021, 07:18 AM #3328
Screaming And Flying!
- 15,062
- 407
- 1450
- 6008
- 11667
I know a guy with a 20' Lake and Bay with the 250 SHO nizpro S/C It does 101. So 475 hp? IDK about that. Did mid 80's with the same 250 Stock. Same hull with 300 XS would run high 90's. He was expecting more.
marks86 thanked for this post
03-08-2021, 07:56 AM #3329
Remember those old Land and Sea catalogs and the amount of HP you would have If you bought this...
All I know is Monty ran the first boat I made that was the heaviest, 2 skin coat coremat 2 1708
stock 225 Johnson 29 SRX his 99.8 mph with 5 min seat test time
that's a 20' 6" boat
03-08-2021, 08:49 AM #3330
Supporting Member
- Jul 2004
- Connecticut
- 6,264
- 518
- 205
- 1074
- 1127
In the meantime, a contender for a spot on "The List" in 2021 is the Chaudron Pro S22 deep V.
They are starting to show up in the US and the 24 degree V’s are proven in rough water unlike some other hulls mentioned which are more lake boats.
Max speed for the S22 with a 300XS with DBR 1.3 trying different props yielded 95mph. They've not yet mounted a 300R. A normal build with a 250XS weighed about 2200 lbs fully rigged. Maybe Chaudron USA will work with Nizpro to create a test boat. There are a lot of Yamaha’s in Florida according to S&F guys down in that area, but not sure anyone has seen a flashed Nizpro SHO. Evidently the ECU from them brings the V6 to 332hp.
Not sure if the factory warranty from Yamaha still stands but a "squat" 505lb V6 with 332hp and factory lwp might make a nice, fast package all around seeing as Merc has no performance V6 option anywhere to be seen unfortunately.
