    Feb 2003
    Rochester, NY
    Quote Originally Posted by 282 View Post
    In the video he says it's not a race boat, it's a family boat. Pretty wild family boat. And a Tuff would be fun to see with one of these on it.
    Agreed and yes, I did hear that in the audio. But my Progression 22 is a family boat too and it runs a couple of ticks under 90 MPH with only 250 HP.
    1992 Progression 22
    Mercury Racing 250R
  2. #3317
    PARADISE /Naples
    Many good points to think about but that Force is the F1 model which is 23'5" and has a cabin. Someone else may know the beam.
    But 20 inches of it is a step platform not running hull.
    The Velocity has a cabin.
  3. #3318
    Apr 2017
    Pomona ny
    Love to see the numbers on the progression.
  4. #3319
    Jul 2004
    Connecticut
    Quote Originally Posted by TooStroked View Post
    Hmmm. Your mission, should you choose to accept it, is to track down the owner of the 450 P22 and get a top speed.
  5. Likes TooStroked liked this post
  6. #3320
    Jul 2004
    Connecticut
    88mph with a 250R and 94mph with a 300XS for Progression's 22. 450R ?
    At these higher speeds does 10hp still get you about 1mph or is it all in the set up. Time will tell.
  7. #3321
    Jan 2017
    Albany NY
    gotta add the extra weight in to consideration as well
    my thought is, was the 22 ever built to run well over a 100? Especially with that much weight hanging off the back
  8. #3322
    Feb 2003
    Rochester, NY
    And I should remember to bring my testicular measurement device with me too since his obviously are waaaay bigger than mine.
    1992 Progression 22
    Mercury Racing 250R
  9. #3323
    FLA
    Hang on
    Progression 22 with a Mercury 450 V8. The first spotted in the world. Top speeds not
    Attachment 483535
    It is hard to find calm water there and he is working on some steering issues helm input is to sensitive (imagine that) . He does have the props to play with some big numbers 32 to 38 pitch 5 Blades .
    24 Twister
  10. Thanks Greg G thanked for this post
  11. #3324
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    A problem is only a problem when viewed as a problem...
  12. Thanks Greg G thanked for this post
    Likes Grant Conklin liked this post
  13. #3325
    Sep 2010
    north battleford saskatchewan canada
    Prop is a 30 pitch Bravo - gear ratio is 1.75 - limiters are set at 6400 - speed calculates to 103.4
  14. Thanks Greg G thanked for this post
  15. #3326
    PARADISE /Naples
    blueprint the pad area?
  16. #3327
    Oct 2016
    Amityville, NY
    Quote Originally Posted by Z06man View Post
    Is he running any kind of ballast up front?
  17. #3328
    I know a guy with a 20' Lake and Bay with the 250 SHO nizpro S/C It does 101. So 475 hp? IDK about that. Did mid 80's with the same 250 Stock. Same hull with 300 XS would run high 90's. He was expecting more.
  18. Thanks marks86 thanked for this post
  19. #3329
    PARADISE /Naples
    Remember those old Land and Sea catalogs and the amount of HP you would have If you bought this...
    All I know is Monty ran the first boat I made that was the heaviest, 2 skin coat coremat 2 1708
    stock 225 Johnson 29 SRX his 99.8 mph with 5 min seat test time that's a 20' 6" boat
  20. #3330
    Jul 2004
    Connecticut
    In the meantime, a contender for a spot on "The List" in 2021 is the Chaudron Pro S22 deep V.
    They are starting to show up in the US and the 24 degree V’s are proven in rough water unlike some other hulls mentioned which are more lake boats.
    Max speed for the S22 with a 300XS with DBR 1.3 trying different props yielded 95mph. They've not yet mounted a 300R. A normal build with a 250XS weighed about 2200 lbs fully rigged. Maybe Chaudron USA will work with Nizpro to create a test boat. There are a lot of Yamaha’s in Florida according to S&F guys down in that area, but not sure anyone has seen a flashed Nizpro SHO. Evidently the ECU from them brings the V6 to 332hp.
    Not sure if the factory warranty from Yamaha still stands but a "squat" 505lb V6 with 332hp and factory lwp might make a nice, fast package all around seeing as Merc has no performance V6 option anywhere to be seen unfortunately.
Name:	Chaudron Pro22Keel.JPG
    Attached Thumbnails Attached Thumbnails ChaudronProS22Trimmed.jpg   Chaudron22Buckets.jpg   ChaudronGauge.JPG   YamahaSHONizproECU.JPG
Page 222 of 271 FirstFirst ... 122 172 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 ... LastLast
