Results 1 to 15 of 26
03-03-2021, 09:00 AM #1
5000 RPM
- Dec 2019
- Spring Lake MI
- 604
- 53
- 214
- 547
Favorite Seastar dealer with knowledge?
Need to place an order but would really like to make sure the details are right. Any vendors here? Steering and jack plate stuff.
TJ @ Baker Engineering
Tuff 24 300xs
Tuff 16 90 Yammie
3.75@199mph with LSX power!!!
03-03-2021, 10:38 AM #2
We here are much more knowledgeable than ANY dealer.
Ask away
Smalltownbassin liked this post
03-03-2021, 12:47 PM #3
From a steering standpoint, BoatSteer are a great resource and more than wiling to just talk about options. http://www.boatsteer.com. For Jack Plates I use https://www.seatechmarineproducts.co...lic-jackplate/. While they aren't an installing dealer they have some of the best prices in the US and a lot of knowledge about the product and are not afraid to reach out to Dometic (SeaStar) when needed.
Mark
03-03-2021, 01:03 PM #4
6000 RPM
- Aug 2015
- Southeast
- 1,283
- 139
- 124
- 58
- 794
I'm no expert but the 4 sea star systems I've had all had a small amount of side to side slop in them. Each was basically identical. I don't believe it was air as I tried bleeding a couple of them a couple times. The one Uflex I had was rock solid with no slop. I'm going with Uflex for any new systems I buy. AnchorExpress had the Uflex system at $880ish plus hoses put you at $1k. Back ordered.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship" Sold
Blazer 650 Pro Tour
30ft Cobra with Triple 280's
03-03-2021, 01:26 PM #5
I was wondering that about my seastar system. I even bought a hose and fitting kit just to bleed the system of what i thought had to be air in it. Not a single bubble purged and i still have about 1/2 inch of play either way on the cylinder and the helm has about an inch both ways before you can feel it actually push fluid. I was about to start replacing parts! The play in the cylinder is a real PITA especially at idle when she likes to sound good. Dang motor looks like its gonna have a come apart back there but its just the loose sea star cylinder.
03-03-2021, 04:21 PM #6
www.InjectorService.com
Call/Text - 204-326-0390
03-03-2021, 06:47 PM #7
6000 RPM
- Aug 2015
- Southeast
- 1,283
- 139
- 124
- 58
- 794
None of mine have moved a half inch at the hydraulic cylinder. I'd say maybe an 1/8 inch total play. 1/8 at the cylinder is a decent about of movement at the rear of the motor. All were close to identical so I chalked it up to that being normal. My uflex didn't move any material amount.
Blazer 650 Pro Tour
03-03-2021, 07:14 PM #8
Seastar pro has about an 1/8” or less movement after careful bleeding. I didn’t notice any slop feeling at speed it was tight. If it’s bled properly you cannot turn the wheel past it’s lock no matter how hard you try. Bleeding was a challenge and requires a couple cracks at it over a couple days to get the micro bubbles all out.
I posted a link and how to do this here a couple years ago. I can dig it up if you likeHydrostream dreamin
03-03-2021, 07:46 PM #9
5000 RPM
- Dec 2019
- Spring Lake MI
- 604
- 53
- 214
- 547
Interesting, I keep looking at the Silversteer too.....decisions!
Tuff 24 300xs
Tuff 16 90 Yammie
03-04-2021, 06:53 AM #10
In previous discussion here it was said that the seastar valve switching is what causes this tiny bit of play vs the uflex which is apparently different somehow? Only what I read keep in mind. Brand bias and whatnot is something to consider there doesn’t seem to be a lot of love for seastar brand here. Seemed the same way with etec brp too, and omc.
I can tell you this much I had two rigs with tight dual cable steering and the seastar was superior in every imaginable way imo. A massive upgradeHydrostream dreamin
03-04-2021, 06:57 AM #11
I used the bleed system kit you can purchase. Its simply a hose with fittings that is connected to both bleed barbs on the cylinder. Once you connect it you have to put another hose on the fill port at the helm with a bottle of fluid attached to let fluid in as the air comes out. I spent 30 minutes turning the wheel several dozen times one way and then the other to push any trapped air to the helm so it could get out. The system was already full of fluid and i never saw a single bubble rise up the fill tube or move from one side of the cylinder to the other. Beats me. I dont have any leaks either. Any thoughts on what the issue could be if its not air?
03-04-2021, 07:05 AM #12
I can also force the wheel past full stop either direction in small increments. You think the problem could be bypass in the helm or you still leaning on air somehow being trapped in that wont purge? I guess i could start with replacing all seals anyway even though there aren't any leaks. That's definitely cheaper than a new helm. I don't like the idea of throwing money at something with hopes that it sticks somewhere. Id like to know the issue. How can i post a video here thats not a link to something on the web?
03-04-2021, 10:44 AM #13
I'm not a steering expert by any means, but in my personal experience, I used to fight with steering systems and they were really tough to get right. Once I started using the power purger, it went so quick and was so much easier. Its a big expense I know, but I won't be without one again. Now if this is a one off situation, maybe you want to bring it to a shop that has one, or see if you could borrow/rent theirs?
As far as other possible causes of this, I'm not an expert so I will leave it to someone else to answer. Maybe a sticking check valve or something?
Blake
Smalltownbassin thanked for this post
03-04-2021, 10:55 AM #14
Have you tried this ?
Absolute easiest way to bleed seastar uflex hydraulic steering system - YouTube
22R
03-04-2021, 02:49 PM #15"The character of a man can be easily judged by how he treats those who can do nothing for him"
25two.stroke liked this post
lower knowledge
By 78checkmate in forum Technical DiscussionReplies: 9Last Post: 06-07-2012, 04:48 PM -
Sharing some knowledge
By ShorePounder in forum Technical DiscussionReplies: 6Last Post: 03-25-2002, 09:20 AM
