Results 1 to 4 of 4
    Jan 2021
    Seattle
    Sst 120 - propeller shaft height
    I am looking if anyone has specifics or a range of what the SST120 tunnel boats run from the bottom of the center pad to the centerline of the propeller shaft.
    Has nothing to do with the center pad, be prepared to do a lot of testing. Nose cone centered with the bottom of the sponsons is where I started, then the rest depends on lift, angle of attack, propellers, how fat you are, center of gravity and probably ten other magical aspects.
    Celina, Ohio
    The front runners are running them so high that they are running out of water by end of the straights. They suck water in the turns. Just like leaning them out, it's a fine line between winning and cooking a powerhead
  4. Likes David - WI, Capt.Insane-o liked this post
    Quote Originally Posted by Eprotzeller View Post
    ...welcome to scream and fly...
  1. STV Mod VP Prop Shaft Height
    By Damyankee in forum Props, Setup, and Rigging
    Last Post: 01-16-2009, 11:15 PM
  2. Mercury V6 propeller shaft?
    By Roos in forum Technical Discussion
    Last Post: 08-01-2006, 11:30 PM
  3. ssm prop shaft height
    By Spreadeagle in forum Outboard and Racing History
    Last Post: 08-03-2005, 07:15 AM
  4. Propeller shaft and prop
    By bass60 in forum Technical Discussion
    Last Post: 11-11-2002, 10:54 PM
  5. Shaft Height
    By B.Mac in forum Technical Discussion
    Last Post: 05-10-2001, 07:39 PM
