Results 1 to 14 of 14
    Feb 2018
    Russia
    Does it right 300 pm reeds?
    I had check reeds, wanted to see. And look 2 petal reeds. Does it right for 2000 300pm? Click image for larger version.
ID:	476992Click image for larger version.
    5 Post(s)
    5 Post(s)
    Feb 2018
    Russia
    Nobody knows? I found in specification, that 6 pedal metal reeds must be on 300 pm on stock. My reeds are better?
    Nov 2009
    hardyville va
    Quote Originally Posted by Tranq View Post
    Those are Boyeson 2 stage reeds. I don't like them. Get some CC reeds.
  6. Likes Capt.Insane-o liked this post
    Sep 2017
    Collingwood Ont. Canada
    Those are stock reeds on the 3 300PM's I have taken apart.QUOTE=Tranq;3245123]I had check reeds, wanted to see. And look 2 petal reeds. Does it right for 2000 300pm? Click image for larger version.
    Sep 2006
    Key Largo, Fl
    The motor came with 6 petal steel reeds,you have Boyesen 2 stage ,we make 6 petal single stage...I think you'll like them...
  9. Likes David - WI, Capt.Insane-o, rgsauger liked this post
    Chris's reeds are much better than the boysens.
  11. Likes phillnjack liked this post
    Jan 2003
    aalsmeer
  13. Likes SUNKIST, phillnjack liked this post
    Feb 2018
    Russia
    If i replace 6 pedal cages to 5 pedal and install 5 pedal reeds , what i can get in performance? It's not so cheap in complex, because engine need to rebuild (bore cylinders, i lost compression)
    Nov 2009
    hardyville va
    The juice ain't worth the squeeze. Just CC the 6 petals.
  16. #12
    Jul 2009
    gatineau qc, canada
    can the same ccm reeds be used with cages that the rubber was stripped off?
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
    Yes.
  18. #14
    Sep 2006
    Key Largo, Fl
    We now have a special cut reed for the rubber off cages,a little larger sealing area than the standard ones,same price,in stock,Chris
  19. Thanks mistah_max, phillnjack thanked for this post
  1. Replies: 18
    Last Post: 04-05-2022, 05:35 AM
  2. Mercury Tech: fiber reeds and steel reeds in same motor
    By buzmacdowell in forum Technical Discussion
    Last Post: 07-09-2011, 10:06 PM
  3. horizontal reeds v/s vertical reeds?
    By david martin in forum Technical Discussion
    Last Post: 12-04-2007, 06:09 AM
  4. BOYESEN REEDS VS LAND & SEA REEDS
    By MrCougar in forum Technical Discussion
    Last Post: 05-14-2001, 07:08 AM
