Results 16 to 30 of 32
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    From what I have read the orig. 5605 is a petro. based product. it is now obsolete. The 5606a is a mineral oil based prod.
    You do know mineral oil is petroleum based right?
    1996 Checkmate Pulsare 2100 with a 2017 Merc 250 Pro XS
  2. #17
    I do know mineral oil is refined further....But, yes from petro.
    Gothenburg, Sweden
    do you think the original 5606 spec was based on crude oil?
  4. #19
    X/C® 5606H Aviation Hydraulic Fluid meets the cleanliness requirements for “super clean” hydraulic fluid for use in modern aircraft hydraulic systems.
    X/C® 5606A Aviation Hydraulic Fluid is recommended for use in hydraulic systems that do not require a “super clean” fluid.
    Both fluids are dyed red for identification and leak detection purposes.
  5. #20
    Quote Originally Posted by Markus View Post
    No, I thought it is dinosaurs put in a jar. Seriously, wtf marcus? So petty. Ok here it goes....
    Mineral oils are produced from refined hydrocarbons obtained from crude oil by distillation. They are applied as
    hydrodynamic lubricants and as carriers of additives promoting boundary or solid-film lubrication.
    But some people call them "super clean fluid". Thx for the info David WI...
  6. Likes David - WI liked this post
  7. #21
    Gothenburg, Sweden
    So what do you mean it is based on if not a mineral oil base stock?
  8. #22
    Find some citroen oil and shove it buddy....You must be really bored huh? If you want to be an oil expert look it up yourself....
    Moline,Ill
    From what I have read the orig. 5605 is a petro. based product. it is now obsolete. The 5606a is a mineral oil based prod. The newer designations H to J now have changed to meet the ultra low temp requirement for the military. The snow plow stuff is the closest to original 5606 you can get I would guess. All the designations would be OK afaik. Each letter higher is a new latest and greatest variant. With mil spec they always want better as the aircraft operating parameters increase. Snowplows not so much....
    Well since you poo poo'd me I'll jump in, you better be careful what your recommending, this is from the 5606H info sheet.
    " NOTE: Do not use these fluids in hydraulic systems with natural rubber elastomers ".
    is gone
  10. #24
    I thought I was saying the snow plow stuff was the closest? Not meaning to poo poo you buzzin. I use the napa stuff since I go there for a lot of parts. The mil spec changes and you have to read the bottle for every one.
    Moline,Ill
    My mistake
    is gone
  12. #26
    Feel free to correct me any time buzzin. I will be the first to admit i'm not an oil espert...There was a thread a while back about this? That's when I quit the sea star snake oil.
    Like everyone here, I listen to what everyone else says and then do what I want. Hahaha.....
    Gothenburg, Sweden
    That was not particularly polite. However, you have posted much worse things.
    I am no oil expert, but I have worked in the industry. I have also owned boat engines and cars, and have learned enough to know what I need to know to make informed decisions.
    I encourage you to read up a bit on lubrication. On the other hand, in light of some of your other posts, you have much more important things to read up on.
    Believe it or not, but your lack of knowledge isn't as good as someone else's knowledge, and does not deserve to be respected.
    __PRESENT
  14. #28
    Middle Georgia
    Well, it all boils down to the fact, "It's my boat and I can run whatever I dang well please" If one choses to ignore the manufactures recommendations because they fell the know better than the engineers, that designed it, that's totally up to them.
    Keith Jones
  15. Likes XstreamVking liked this post
  16. #29
    __PRESENT
    Dammit man say what you mean. Don't beat around the bush. You don't like me? Oh, well. Feelings mutual....
    Dec 2017
    Quote Originally Posted by TraceF3 View Post
    Phillips, Shell, or Royco aviation hydraulic. Under $30/gallon.
    You can use these options.
    I am retired from the lubricants industry. Lubricants have become more and more complex over the last few decades but this is a fairly basic hydraulic fluid.
    Consider that Sea Star isn't making their product, it takes a specific grade of base stock refined to blend with a specific combination of additives. They're buying it from the lowest bidder and the same blend is probably going in lots of other bottles, pails, and drums that aren't labeled Sea Star.
  18. Likes JR IN JAX liked this post
  1. Seastar tilt helm and Seastar front mount ram
    By 87starflite in forum Misc. Parts and Accessories
    Last Post: 04-16-2014, 11:31 AM
  2. Seastar Hydraulic Pro.. fluid...
    By jay1 in forum Technical Discussion
    Last Post: 03-31-2009, 08:03 AM
