Results 1 to 15 of 50
01-01-2021, 02:53 PM #1
5000 RPM
- Sep 2012
- Las Vegas
- 163
- 12
- 10
- 20
- 15
Sportmaster oil fill level practices?
1. Many here say they level the lower unit, and fill from bottom just until it comes out of top vent hole. A 32 oz. bottle will NOT be enough.
a. -Some say they have done this for years with no problems
b. -Others say it "blew"out the top driveshaft or shifter seals.
c. -Yet others say that if you DON'T fill to the vent hole, the top driveshaft bearing and seals will "run dry" and not be lubricated.
2. Dealer, and some others here say measure and fill only 28 oz. It will NOT come out the top vent at 28 oz.
3. Still some others here, say their manual says to fill with 24 oz., even less than above.
Which is correct? Or does it even matter?
Mine is 2007 sporty on 300xs if that matters.
01-01-2021, 03:37 PM #2
Put an expansion kit on it.
01-01-2021, 05:20 PM #3
On a 3 liter sportmaster, fill from the bottom until it comes out of the top then drain off about an ounce. It will take more than a quart. Maybe 34-36 ounces. I have done it this way for years and have never pushed out a seal much less burned up any bearings.
Sleek Jr thanked for this post
01-01-2021, 06:24 PM #4
1996 Checkmate Pulsare 2100 with a 2017 Merc 250 Pro XS
01-02-2021, 03:57 AM #5Markus' Performance Boating Links:
01-03-2021, 10:59 AM #6
When you follow the proper fill procedure it’s not a problem. That’s why you drain about an ounce of oil off after filling. It provides the space needed for the thermal expansion. And it cost you nothing, no need to purchase an expansion kit.
01-03-2021, 11:07 AM #7
I did try this. I had 3 trips in 7 hours to the l/u guy. Kept saying it was holding pressure. Kept changing the lube and getting more water.
I think when you are running the sporty at full surface for long periods of time it gets hotter than we realize. The kit stopped my problem. So it worked for my situation.
XstreamVking liked this post
01-03-2021, 02:01 PM #8
When you guys are talking about a expansion kit are you talking like the ones found on Bravo I/O's ?. If so is it mounted also mounted on the transom?.. Stupid question of the day..
01-03-2021, 05:38 PM #9
It's not a bad question. I'd never heard of it either.
Shop | MadEFI.com
First item on the GEARCASE tab
big tom liked this post
01-03-2021, 06:03 PM #10
5000 RPM
- Sep 2017
- ontario
- 761
- 72
- 48
- 78
- 199
So I have followed the thread - am I to understand that the 2.5 Sportmaster does not take the same fluid capacity ? .
Manual states - capacity at 22.5 fl. oz. And to fill to vent and not to lose more than 33 CC. Please correct if differant . Thanks
01-03-2021, 07:29 PM #11
On a 2.5 you can fill it until it just starts to come out of the vent.
Lakeland Marine makes a vent kit for the 3 liter cases for the folks who like to overfill them.
http://www.optimaxfuelrailrepair.com/services.html
01-03-2021, 08:53 PM #12
28oz for the 3L sporty , I’ve never had a problem
2003 mirage ski racer with e-tec power
01-04-2021, 05:42 AM #13
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,372
- 1078
- 420
- 4785
- 2198
- 9 Post(s)
what happens all depends on the conditions under which the box operates.
very high and hot water or very little coming down its going to get very hot blow the oil out then pull the water in when it coolsLast edited by powerabout; 01-04-2021 at 06:24 AM.
01-04-2021, 09:41 AM #14
Doesn't everyone run their Sportmaster "very high"? Otherwise whats the point of having a Sportmaster? I run mine where the pointed leading edge is above just above the waterline, if I ran it any higher there would be no water pressure. It's about 1 3/8" to 1 1/2" above the bottom of the hull. For over 10 years now I have filled from the bottom to the vent hole, then lazily put the plug in allowing about an ounce to an ounce and a half of oil to drain off. Maybe I'm lucky but I have never had a problem with this case pushing out seals or ingesting water. I change my gearcase oil about monthly during the season and this boat gets alot of use. To each his own...
01-04-2021, 11:13 AM #15
6000 RPM
- May 2001
- Maine
- 1,089
- 13
- 41
- 105
- 213
Any photos of the Lakeland Marine system installed other than what's on their web site? It would be nice to see how the vent hose is routed and the placement of the expansion chamber under the cowl?
Question for the - to fill or not to fill the notch?
By Pachanga_rick in forum General Boating DiscussionReplies: 16Last Post: 04-09-2019, 02:12 PM -
What would you use to fill this gap?
By bigboy in forum Fiberglass and Composites DiscussionReplies: 13Last Post: 09-05-2010, 08:34 AM -
Trs to B1 fill in or not?
By scippy in forum Fiberglass and Composites DiscussionReplies: 3Last Post: 04-11-2009, 05:25 PM -
What to use to fill Sportmaster
By Stoker100 in forum Technical DiscussionReplies: 12Last Post: 02-07-2005, 09:51 PM -
Merc ain't the only one that practices price gouging!!
By Greg Moss in forum General Boating DiscussionReplies: 4Last Post: 08-22-2002, 09:06 AM
