Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 16 to 30 of 131
    Central, PA
    Sounds great! Can't believe how high the nose runs with that cleaver. Like Insano said, make a pass with some ripple in the water and it'll be faster
  2. Likes mrcrsr liked this post
  3. #17
    Shreveport, La.
    I wish that 115 had enough steam to plane the SSM. Maybe a smaller prop if anybody has one to loan. That SSM is so efficient it just locks the prop up to the water.
  4. Likes mrcrsr liked this post
  5. #18
    May 2001
    Ga
    Maybe some sort of vent tube to break the prop loose , like the mc # 6 drives. Just rig up something temp for testing. hf...
  6. #19
    JUPITER, FLORIDA
    Skip dinner and breakfast, throw on a pair of speedos, lose the t-shirt, shave your chest hair and head and go out on a cool morning! You got this Charlie!
    Paramount 21/Merc 225 EFI
    Cobalt 263/VP 8.1L
    Nova Spyder 230/454 Mag
    Barracuda 188CCR/Suzuki 140
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT/Merc 175
    Talon T-21/Mercury 245hp carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/454 Mag
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat
    SeaRay 17' Seville
  7. Likes mrcrsr, rgsauger liked this post
  8. #20
    Quote Originally Posted by half fast View Post
    Yeah this...running the 12 inch takes away the exhaust relief that those little motors need to buzz the prop.
  9. Likes mrcrsr liked this post
  10. #21
    5 Post(s)
    ...whats the gear ratio on that particular mc1?... a number of them were 1.5:1...
  11. #22
    Pekin, IL
    My 150xs T2 with the speedmaster has a hell of a time breaking loose so I imagine with a 115 it's a similar issue. The previous owner added nitrous just to get off the line. I have thought maybe a some type of vent such as half fast has suggested but have not figured that out yet. You'll see 80 next time out. Good job.
    Rock
    Team Junk
  12. Likes mrcrsr liked this post
  13. #23
    Jun 2004
    port st. lucie, fl
    That's the next step is I'll jury rig an external vent hose along the cavitation plate and then up, and just wire tie it in place for testing. As far as the coned case and top end numbers, I'm going to fix some chips in the pad, and try it again, and if that doesn't do it I'll give it some more timing. T2X powerhead is getting built and put on the boat next week, so I'll try this engine one more time
  14. Likes Frank Molé liked this post
  15. #24
    Did you add any additive to the top shelf pump gas?
    Less heat in it , slower burn, need more ign?
    What fuel are you using?
  16. #25
    longisland
    put some race gas in it and turn the timing up more
  17. Likes mrcrsr liked this post
  18. #26
    Put the Wiseco high domes in it , give the ports some more, about halfway to 1500xs , build the proper tuner setup , 10/10 reed, set the carbs and jack the ign to 27° at cranking speed WOT, 25.5° at high rpm, NGK plugs, solid wires , feed the good fuel. No fear.
    It's at 21 now, lazy 19.5° at rpm.
  19. #27
    Houston, TX
    Rain X the bottom and the lower. You will see a 2 mph gain for about an hour.
    Rain X??? Interesting
  20. #28
    Quote Originally Posted by RONNIE View Post
    Yeah, 3 gallons of race gas is probably worth 1/4 mph versus 18 gallons of premium...100 pounds.
  21. #29
    May 2016
    Upper Potomac River
    I'll catch hell for this and I'd never do it to my Viper
    ...remove windshield
  22. #30
    Same XS powerhead would run 83 on my viper and 81 on my Vector. Both are close in weight but the viper manages air much better for natural bow lift.
    If your running corn gas it is not going to tolerate timing..some rec 90 and 1/2 110 yes. A cooler morning with some ripple will get you there.
  23. Likes mrcrsr liked this post
  1. Who's hitting the gym??(weightloss)
    By Mastercraft241 in forum The Scream And Fly Lounge
    Last Post: 10-03-2008, 08:12 PM
  2. Hitting the limit
    By HighVelocity in forum Props, Setup, and Rigging
    Last Post: 10-03-2005, 12:22 PM
  3. hitting the rev. limiter still
    By joey jamz in forum Technical Discussion
    Last Post: 09-22-2004, 06:58 PM
  4. have to keep hitting refresh...
    By Talon2.5 in forum General Boating Discussion
    Last Post: 04-05-2002, 10:42 AM
