Results 1 to 15 of 17
Thread: 1963 Johnson 75hp
12-07-2020, 05:50 PM #1
1963 Johnson 75hp
I`m working on a 1963 Johnson 75hp V-4. Does anybody know the ballpark compression?
12-07-2020, 07:33 PM #2
Screaming And Flying!
- Dec 2001
- 9,487
- 271
- 191
- 1979
Don't know.....if all close...... good Nu'f.....Is a eltric shift ?.....
12-08-2020, 02:38 AM #3
if it's dumping as much gas as it burns in the water it's perfect.
12-08-2020, 03:50 AM #4
- Dec 2001
- 9,487
- 271
- 191
- 1979
Cut the block deck surface so piston is even with the deck.......them motors had no squish band.... thats why they wasted gas..... Here we go
........Put a 140 PH under the hood.........
12-08-2020, 02:27 PM #5
Yes electric shift. Yes it dumps lots of fuel into the lake.
NICE PAIR liked this post
12-08-2020, 03:23 PM #6
The Historic Photo Master
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
12-08-2020, 04:03 PM #7
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
Nice Pair was working on one, few yrs newer. They had that temp heated choke, burn a gallon on warm-up and idling away in 3 minutes.
12-08-2020, 05:03 PM #8
I rebuilt/restored a 1967 65 hp years ago and it was 115 psi with new internals.
12-08-2020, 07:02 PM #9
Got her running pretty smooth with little smoke.
12-08-2020, 07:04 PM #10
FMP liked this post
12-08-2020, 07:34 PM #11
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
I like Dave S's idea, tighten it up a little if possible.
12-09-2020, 06:16 PM #12
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,625
- 21
- 270
- 219
- 524
- 5 Post(s)
Those had 85 to 90 on my snap on gauge when right. They do waste a lot of fuel.
12-12-2020, 01:28 PM #13
5000 RPM
- Feb 2003
- 255
- 31
- 97
- 3 Post(s)
A friend bought a wood runabout with one of those on it wanted to go skiing. Put boat in ran out to his favorite spot not far. Got him up skiing about five minutes motor quit. Hit the key motor spun did not start went to the back of the boat reached down grabbed the 6 gallon can from under rear splash well about did back flip over the side can was bone dry. Not what I was used to in fuel consumption.
Enjoy Time at the Pump Keith
12-12-2020, 01:56 PM #14
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
Down draft set up on that? Build a new intake and set a small Holley 4bbl on it, probably use less gas.
12-13-2020, 10:58 AM #15
- Dec 2001
- 9,487
- 271
- 191
- 1979
Or...... a v4 suzzikee.......
3hp 1963 Johnson
By Chuck Mostaka in forum Props, Setup, and RiggingReplies: 0Last Post: 07-18-2010, 08:54 AM -
1963 75hp Evinrude --Selectric Shift--Starflight 5.
By hydroViper235 in forum General Boating DiscussionReplies: 8Last Post: 08-08-2009, 09:36 PM -
Small rib with 75hp Johnson
By Reinier in forum Props, Setup, and RiggingReplies: 10Last Post: 12-01-2008, 07:33 AM -
1981 Johnson 75hp 3 cylinder
By dmoss69 in forum Technical DiscussionReplies: 10Last Post: 04-06-2004, 02:26 PM
