Results 1 to 9 of 9
08-15-2020, 05:12 AM #1
Member
- Apr 2020
- Australia
- 42
2011 Mercury 200hp pro xs differences
Hi scream and fly,
have been searching the internet and can’t seam to find a straight answer. Looking at purchasing a 2011 200hp pro xs. Ideally wanted a 225-250 but in Australia they are hard to find.
i know with the 225-250 pro xs you get solid mounts, carbon reeds, ecu with higher rev limiter and more aggressive tune. But what about the 200? Do you still get all of the above features? Just don’t want to buy it and wish I had gone the bigger motor.
Cheers
08-15-2020, 05:57 PM #2
5000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
The 200 has all the same stuff as 225-250
A regular optimax is cheaper will give good performance also upgrade reeds to fiberglass
Promaxin thanked for this post
08-16-2020, 03:13 AM #3
Member
- Apr 2020
- Australia
- 42
Thanks 2jz, just thinking maybe that little extra hp and rpm range will make it perform close to a normal 225 Optimax
11-25-2020, 03:43 PM #4
5000 RPM
- Mar 2009
- Seymour, Tn
- 177
The 200 ProXS and 200 Optimax are the same motor. The 200 ProXS has no upgrades like the 225 and 250. Decals are the only difference. This comes from Merc University and in the tech handbook it says “The 200 meets the criteria for the ProXS rating “.
11-25-2020, 03:45 PM #5
5000 RPM
- Mar 2009
- Seymour, Tn
- 177
I have rebuilt several of them and none have carbon fiber reeds and the have the same rev limiter.
11-25-2020, 08:03 PM #6
Member
- Sep 2020
- Mississippi
- 56
Carbon Reeds are on all Merc Racing, 250xs, 300xs etc
11-26-2020, 11:46 AM #7
5000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Mercury pro xs is different from regular optimax
All pro xs has carbon fiber reeds, different heads,higher rev limiter and list of other stuff https://youtu.be/0lmqAxyBI5s
11-30-2020, 10:27 AM #8
Direct from Mercury's product release:
You asked for it so here it is - the 200hp Optimax with Pro XS graphics to make it more attractive to bass customers. The Optimax 200 Pro XS targets the 18' - 20', 200 hp max rated hulls - providing superior performance over a standard 200 hp outboard. Available only as 20-inch model.
Carbon fiber reeds
Improve performance and efficiency
Are more durable and responsive than stainless steel
RPM range of 5000 - 5750
Unique Attenuator
The intake silencer allows more air in while at the same time reduces overall noise
Exhaust port tuning
Cylinder port is designed to let exhaust out - allowing the engine to build more torque and horsepower
ECM Tuning
Fuel flow and spark advance are set for maximum power output and efficiency
Engine Type V-6 60°
Displacement 185.9 cu. in (3032 cc)
WOT RPM Range 5000 - 5750
Fuel System 2-stage DFI
Alternator 60 amp
Gear Ratio 1.75:1
Shaft Length 20 in (508 mm)
Dry Weight 505 lbs (229 kg)
Does have carbon fiber reeds, a quieter air attenuator, and a "maximized" calibration. Very little, if any difference from the standard 200 Model. Averages about 220hp at the propshaft.
This model was intended as a "market competitor" in the 200HP High Perf category.STV Euro 2.5XS -sold
Baja 252 Islander 496 Mag
Nitro Z7 200 Pro xs
05-15-2021, 10:27 PM #9
Member
- Apr 2020
- Australia
- 42
Eventually got to the bottom of it, early 200 pro xs is the same as the 200, no performance modifications until late 2012.
http://www.bbcboards.net/showthread.php?t=25431
HELP! Mercury 3.0L block differences
By Mxdude91 in forum Technical DiscussionReplies: 46Last Post: 01-04-2019, 08:49 AM -
What is the differences between 175 and 200hp Yamaha circa 2007
By foodie in forum General Boating DiscussionReplies: 2Last Post: 12-14-2018, 08:59 PM -
Any differences in the Mercury 3.0L Powerheads?
By speedthriller in forum General Boating DiscussionReplies: 13Last Post: 10-15-2016, 11:16 PM -
Mercury 2.5 tuner differences
By capteliminator in forum Technical DiscussionReplies: 6Last Post: 09-12-2013, 06:33 PM -
Mercury 3.0 225 model differences
By Matt Gent in forum General Boating DiscussionReplies: 3Last Post: 01-12-2005, 01:17 PM
