Page 26 of 39 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 376 to 390 of 581
  1. #376
    Minneapolis MN
    tnelsmn can you tell me the outside to outside spacing of your trailer bunks? Sooner the better Im in the middle of trying to configure bunks with no boat to measure. Thanks a TON, i hope your near the boat today lol
    Sorry, Lake, I’m at the lake today. I can get measurements tomorrow morning.
  2. #377
    Jun 2018
    Floating around
    It was a hopeful long shot. I guessed and went 32” outside to outside and it’s a bit wide. No rush now but I will still be thankful to know. Enjoy the lake I’m on dryland all weekend. Boo lol
  3. #378
    Minneapolis MN
    Plugging away at rigging, slowly but surly. Seems like every time I turn around I'm ordering some type of hardware I forgot about. I'm sure the UPS man is getting sick of dragging box after box from McMaster-Carr to my house. I should say that I've conceded any chance at putting it in the water before it freezes this year. Splash date will have to be in the spring.
    It's almost painful to be cutting so many holes in this thing. But I've been diligent about coating any exposed wood with gel coat and adding 4200 to any screws that are threading into wood.
    Blue LED strip lights were installed about as high as they could be in the deck. They glow well on the interior and make for a neat look. The self adhesive backing lasted a whole day and fell off. If the surface was cleaned better prior to install they might've held. I ended up using a dab of 4200 every few inches and that seems to hold.
    The bow lights are also LED strip style and mounted to the underside of the rub rail gives a really clean look. They are super bright and easy to see even mounted the way they are.
    Helm and steering hoses are installed for good. For some reason I ordered 18' hoses, thats why they come so far forward before turning back to the helm. Having the T nuts installed in the wood supports for the deck worked really well for mounting the hose clamps.
    Gauges are installed and wiring had begun on those. Since the newer style gauges use a harness instead of studs for wiring there's a few extra wires behind the dash. I added three buss bars to gang all the gauges together, I think this is cleaner than splicing all the wires into one. I have to send the switch panel out to be anodized and milled before installing the switches and really getting the wiring done.
    Since the wiring is a bit of a stand still I started working on finishing the work on the trailer. Adding a swing tongue and transom strap hooks. I need the room from the swing tongue before I can get the engine bolted to the jack plate.
    Attached Thumbnails Attached Thumbnails IMG_7023.jpg   IMG_7046.jpg   IMG_7053.jpg   IMG_7051.jpg   IMG_7055.jpg
    IMG_7062.jpg   62139289569__2D2D0FDB-1222-4C5B-BA7E-23B2B41730B4.jpg   IMG_7076.jpg   IMG_7068.jpg   IMG_7069.jpg
    IMG_7070.jpg   62250021857__EE72803D-00C1-4E4E-BF9A-EE855A2A3931.jpg   IMG_7077.jpg   IMG_7078.jpg
  4. #379
    Be a nice ride when your done.
  5. Thanks tnelsmn thanked for this post
  6. #380
    Sep 2017
    Ashland city tn
    I like the lights up under the cap. Much better look and easier on the eyes at night gonna b one nice rig
  7. Thanks tnelsmn thanked for this post
  8. #381
    Jul 2005
    AZ
    You are going to straighten up that wiring before you finish right?..lol
    Looking good?
  9. Thanks tnelsmn thanked for this post
  10. #382
    Minneapolis MN
    Thanks guys!
    Waiting on my switch panel to get back from being anodized and machined before I can complete the wiring. I told the shop no rush to hopefully save a few bucks.
    The trailer work is finished and the new winch and jack are on. Fulton makes some really nice pieces. I added some laser cut stainless steel emblems to the trailer for a little extra finishing touch.
    I started in on the cone job on the lower. This is the original 2:1 preload case, we'll see how long it lasts.
    I 100% TIG welded the cone to the case. I fabbed a water passage from 1/8" sheet metal, I just never really liked the look of the hose. A trim tab was also cut from sheet metal and welded to the skeg. I followed the article posted on Wave to Wave and filled the farthest starboard water inlet and also slightly blunted the point of the nose.
    The filler and paint work are left to be done, I plan to paint the lower and mid with Imron once finished.
    Attached Thumbnails Attached Thumbnails IMG_7092.jpg   IMG_7124.jpg   IMG_7102.jpg   IMG_7104.jpg   IMG_7108.jpg
    62416022913__A11AE43C-A2E4-4122-929D-C92C03931579.jpg   IMG_7112.jpg   IMG_7115.jpg   IMG_7118.jpg   IMG_7119.jpg
  11. #383
    Nowthen, Minnesota
    Rumor has it you might do my next cone job... HaHa Looks awesome bud!
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  12. Thanks tnelsmn thanked for this post
    Likes Merc 2.5 liked this post
  13. #384
    Aug 2003
    lakeville MA
    Tony what happened to your Instagram?
    craig Harrison
    81 Hydrostream Vector
    21' pontoon boat
    14' GW Invader (sold)
    17' action 2.4 merc (sold)
  14. #385
    Minneapolis MN
    First layer of epoxy putty is on the lower unit. I'm surprised at how thin this stuff is. I don't see how you could use the epoxy alone to hold the cone on as the instructions from Bob's would suggest. Anyway I can already see there's a few low spots and will need at least another coat after sanding the high spots of this down.
    I set the cone aside since more of my wiring supplies arrived. I want to continue with the wire until it's nearly finished, then get back to the engine.
    I added a 6 place fuse block behind the dash to power up the majority of the accessories, this also has a 6 place negative buss bar built in. I added the main 12 place buss bars under the splash well near the battery.
    3 of the 4 speakers are mounted. The last one will have to wait as control cables and the engine harness will need to route behind it and it will be in the way.
    I ordered all my wiring supplies from Pro Wire USA. It's their "Tefzel" wire, which is tinned wire and some impressive insulation thats also nice and thin.
    Yes I'm crazy and all the wires are labeled where they terminate, and every screw that goes into wood has a liberal amount of 4200 on it. The wires look a bit sloppy now but will be tidied up once they're all in and I can snug up the zip ties.
    Attached Thumbnails Attached Thumbnails IMG_7123.jpg   IMG_7126.jpg   IMG_7137.jpg   IMG_7140.jpg   IMG_7141.jpg
  15. Likes Merc 2.5, LakeFever, Hippie459MN liked this post
  16. #386
    Sep 2017
    Ashland city tn
    Quote Originally Posted by tnelsmn View Post
    Well I deleted all my social media for a while so you might see me on here a bit more.
    Only social media I do is scream and fly. I have no other anythings , I like it like that. But back to your rig. I was talkin to a buddy yesterday (member here) and we was talkin bout spraying gel and he said man thats gotta b hard , I then started telling him bout your build and being your 1st one and seems like you been doin it 30yrs , then I told him u said really wasn't all that hard. You have really went the extra 100 miles on this. Patience pays off i guess. Thats where I struggle, always wanna b n a hurry. Gotta make myself slow down
  17. Thanks tnelsmn thanked for this post
  18. #387
    Minneapolis MN
    Thanks for the kind words, Merc. As far as spraying the gel. It is a lot of work, but I wouldn't call it difficult. Not to take away from guys who are good at it, but the stuff is so thick and comes out of the gun so slow its very forgiving compared to say automotive paint. I don't think gun technique is nearly as important with gel. It is very labor intensive with sanding and buffing, but agin more labor than skill. Then agin I've only sprayed my boat and could just as easily eat my words on the next project haha.
    I've been blessed with a lot of patience. I find very tedious work almost relaxing.
  19. #388
    Nowthen, Minnesota
    I was wondering where you went or what happened. I have not been on the old social media much myself as of late. If it wasnt for the groups and pages I have, I would get rid of it as well.
    -Kevin
  20. Likes tnelsmn liked this post
  21. #389
    Minneapolis MN
    November 16th marked two years since it was pulled in the garage. I can't believe it's been that long!
    Still plugging away with the wiring. I've been busy with lots of other stuff the last few weeks so progress has been kinda slow. But a few more things are done.
    Bilge pump is mounted, plumbed, and wired in. I changed the wiring a bit so that instead of running the auto feature directly to the battery it will pull power from the hot side of the master switch on the dash. That way when I throw the main battery switch in the rear, everything is off. The plumbing had to get a little crazy to get out from the bilge and around the knees and fuel tank. There isn't much extra space around the tank. The black on the hose is actually heat shrink hose clamps. Saw them in Hot Rod magazine years ago.
    The radio and all speakers are finished. I did buy a 12 pin Deutsch plug for the radio so it can be removed easier in the future if needed. The antenna is mounted below the bow to keep it hidden. It gets good reception inside my garage even on iffy local stations. I'm surprised at how well this set up sounds and the fact that the entire thing is completely hidden is cool. The head unit has an app to control every feature from a phone so you don't need to see it. But there's very few buttons and it's easy to control by feel.
    The original horn and USB charge port are mounted and wired, everything forward of the dash is now finished.
    Attached Thumbnails Attached Thumbnails IMG_7145.jpg   IMG_7163.jpg   IMG_7213.jpg   IMG_7210.jpg   IMG_7212.jpg
  22. Likes 89LASER, LakeFever liked this post
  23. #390
    Nov 2019
    Canada
    All I can say is WOW! I just finished reading this thread front to back, I kept waiting for the part where you might skimp out on a detail, or something, but you didn't! It seems like you have thought about every detail, from trailer to motor, to boat and everything in between. The labor hours involved are unreal too! WOW GREAT JOB!
    EDIT: And documenting every detail in the process too, that in itself is difficult at the best of times, and takes a huge amount of time.
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
  24. Thanks tnelsmn thanked for this post
    Likes LakeFever, Gw1nels175 liked this post
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. complete rebuild Monster Viking
    By primerate2 in forum Appearance Mods
    Last Post: 10-25-2011, 02:14 PM
  3. Blue 1978 viking lansing, mich
    By 200VEGAS in forum General Boating Discussion
    Last Post: 08-07-2010, 09:04 AM
  4. 1978 Galaxy rebuild
    By Auggie2612 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-25-2009, 10:32 PM
