Results 1 to 15 of 49
09-20-2020, 01:19 PM #1
How to determine if you have 2.5 FF block
I have two 2.5 carb power heads on my boat that i am going to be selling. How do you determine if they are ff blocks. thanks, mike
09-20-2020, 02:31 PM #2
Should have FF stamped behind the timing arm. Right where the two halves meet each other.
Before the FF it was EE (200).
Noah Burns liked this post
09-20-2020, 04:28 PM #3
Big, thanks for the reply. What makes these desirable? What years were the produced?
09-22-2020, 05:18 AM #4
I think 94 up til oring came out. The promax 200 is made from ff block ,just no paint on pm 200 the diffrence in the 200 and 225 is front half and ecu and 225 has larger exhaust dumps at bottom of block. But all sleeve porting is same between ff and 225pm and has same (big) exhaust chest. The EE blocks have smaller porting and smaller exhaust chest but they make great torque. Hope it helps
09-22-2020, 08:32 AM #5
I have a FF block and got a spare EE block. Havent been able to try the EE out yet.
Realy wonder how it will perform compared to the FF. Both are stock and carburated.
09-22-2020, 08:44 AM #6
09-22-2020, 08:55 AM #7
Screaming And Flying!
- 15,123
- 414
- 1474
- 6097
- 11780
I have 2, a 98 and a 96 EFI FF block 200's. Very strong runners. The best non hipo engine there is in the 2.5 series. Push my v-king into the 80's. They make about 220 ponies easy.
LakeFever liked this post
09-22-2020, 10:45 AM #8
5000 RPM
- Mar 2015
- DFW
- 661
- 16
- 42
- 366
- 232
09-22-2020, 04:45 PM #9
25two.stroke liked this post
09-22-2020, 04:49 PM #10
mine is a mildish build ff and I got a pretty heavy bass boat and with a 28 I can hit 80 or 82. Not screamin fast but runs good and I beat it to death but stay on the maintenance. Great motor. I have a modified promax im in process building but the port work little more extensive and will be goin on alot lighter boat
09-22-2020, 04:55 PM #11
09-23-2020, 03:53 PM #12
Damn I wish
09-23-2020, 04:01 PM #13
09-23-2020, 07:44 PM #14
David - WI liked this post
09-24-2020, 01:21 AM #15
I kinda like the EE block more better.
how to determine the condition of a powerhead?????
By 2tonchevy in forum General Boating DiscussionReplies: 66Last Post: 05-18-2013, 10:48 PM -
What is it??? Cant determine what type of boat this is
By Mcgrain in forum General Boating DiscussionReplies: 6Last Post: 04-14-2013, 08:43 AM -
How to determine gear ratio?
By at100plus in forum Technical DiscussionReplies: 7Last Post: 09-28-2010, 09:12 AM -
How Do You Determine Production Yr on a Merc??
By Instigator in forum Technical DiscussionReplies: 5Last Post: 12-10-2006, 05:22 AM -
How do you determine what pitch to get?
By Riverman in forum Props, Setup, and RiggingReplies: 13Last Post: 12-06-2005, 10:40 PM
