Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 61
  1. #31
    Apr 2016
    Port perry
    Ok guys need some guidance ive been talking with my local fiberglass dealer and they cant get anything like divinycell but have lots of balsa I've already decided to use expoxy so no need to talk about that but should I just go with balsa and be sure to seal really well or go with the long and expensive shipping/exchange rate for divinycell
  2. #32
    Calgary, Alberta
    Suggestion: it is getting extremely hard to get disposable gloves for fiberglass work right now due pandemic demand and supply chain issues. I’d start scrounging on nitrile gloves right away.
    Matt
  3. #33
    Jul 2012
    Lufkin, Texas
    Balsa is stronger that composite, seal it up good...
  4. Thanks Laseraddict thanked for this post
    Likes tnelsmn, Laseraddict liked this post
  5. #34
    Apr 2016
    Port perry
    Well grinding done and ready for core 1/2 in balsa is the correct thickness for the core
  6. Likes Laseraddict liked this post
  7. #35
    Minneapolis MN
    Looks really good! Yes, 1/2" for the core.
    Is there more core forward of that? Seems like a lot of the Hydrostreams have more core below the forward floor. At least mine did.
  8. #36
    Apr 2016
    Port perry
    No that's the end of the core it's about 9ft of core
  9. Likes tnelsmn liked this post
  10. #37
    Jul 2012
    Lufkin, Texas
    The bottom of my V-King broke right there at the end of the core, I would run it forward to a "V" shape, that will distribute the load better!
    Josh Peterson
  11. Likes Laseraddict liked this post
  12. #38
    Nitro rat is right. Do all the core you can now while it's easy. The bow area takes a lot of punishment. Beef it up.
    Minneapolis MN
    This is where mine had core from the factory and where I put it back. If I do another one I would take it up into the chine anywhere forward of the floor and carry it wider up front(outlined in red). The front edge of the floor seems like a major stress point.
  14. Likes Laseraddict liked this post
  15. #40
    Apr 2016
    Port perry
    Ok will do thanks guys but the original core definitely ened 9.5 feet from the back of the boat
  16. Likes tnelsmn liked this post
  17. #41
    Apr 2016
    Port perry
    Well got the core dry fitted got a question tho should I lay some matt chop strand down first with thickened epoxy and make it realy wet and then wet the under side of the balas then lay in. And add a little bit of weight to keep it in place Click image for larger version.
  18. #42
    Sep 2017
    Ashland city tn
    Tnelsmn has a very detailed thread of his rebuild , alot of questions can be answered lookin at his. Click on link in his signature. Hope it helps
  19. Thanks tnelsmn thanked for this post
  20. #43
    Minneapolis MN
    I had an extra bundle of shingles laying around when I did my build. A dozen or so shingles was a nice big, even, heavy, and flexible weight. Bakers parchment paper worked great to separate the shingles from the balsa.
  21. #44
    Apr 2016
    Port perry
    Well core is stuck down
  22. Likes tnelsmn liked this post
  23. #45
    Nov 2019
    Canada
    Cool project! Looks like it is coming along nicely. I love the color on the boat, she should be great when shes done.
    www.InjectorService.com
    Call/Text - 204-326-0390
  24. Likes Laseraddict liked this post
  1. hydrostream hst core
    By Gassman109 in forum Technical Discussion
    Last Post: 12-07-2016, 08:21 AM
  2. hydrostream Vector core
    By scottmcbx in forum Technical Discussion
    Last Post: 10-06-2014, 07:47 AM
  3. Hydrostream venus core
    By R.I.P. in forum General Boating Discussion
    Last Post: 03-29-2013, 07:44 PM
  4. Hydrostream re-core help
    By FusionFab in forum Fiberglass and Composites Discussion
    Last Post: 04-06-2012, 01:34 AM
  5. new core in the hydrostream
    By cuffer22 in forum Fiberglass and Composites Discussion
    Last Post: 03-07-2008, 06:02 PM
