Page 25 of 39 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 LastLast
Results 361 to 375 of 581
  1. #361
    ...i actually have some new, old stock, mercury lower mounting bolts, for the 1976 thru 1979 V-6's. mercury called them fittings. they were expensive before they became no longer available(NLA) many years ago.
  2. Likes tnelsmn liked this post
  3. #362
    Minneapolis MN
    I think I still have the original engine bolts/hydraulic fittings, I'd have to look, but I'm keeping the three ram trim, so they will just gather dust on the shelf.
    The new rub rail is on! I couldn't bring myself to put a black rubber rail on with this color combo. So this was all fabricated from 14ga aluminum sheet metal. It was formed into the basic shape with a press break. Then an Eastwood shrinker/stretcher was used to form it to the shape of hull. I did have to anneal the portion around the nose to get it to bend that tightly. I had to have to bottom edge formed 1/2" wider than the factory rail for it to function properly in the jaws of the shrinker. Once it was to the shape of the hull that was cut off.
    Everything was then TIG welded into one continuous piece and all the welds ground and metal finished. Finally a part of the project I'm experienced with!
    A bead of 4200 was used to secure it to the hull.
    Deck supports got bolted to the outer stringers. So the hull work is completely finished at this point and I can truly begin rigging.
    Attached Thumbnails Attached Thumbnails 61636914131__64636FFB-81CF-4ED1-9AD8-AFC91146E5C8.jpg   IMG_6939.jpg   IMG_6955.jpg   IMG_6954.jpg   IMG_6957.jpg
  4. Thanks Capt.Insane-o thanked for this post
  5. #363
    Jun 2018
    Floating around
    Wow. Tight work
  6. Thanks tnelsmn thanked for this post
  7. #364
    Nowthen, Minnesota
    Looks awesome! Great work. I still need to bring that fuel tank to ya. lol
    -Kevin
    1982 Hydrostream Vector
    1982 Hydrostream Vamp
    1973 Hydrostream Vixen
  8. #365
    Minneapolis MN
    Fuel tank is mostly finished, just need to add filler neck and drill the mounts. The tank was formed from 1/8" 5052 aluminum and 100% TIG welded.
    Drilled the dash and couldn't help but set the gauges in. I'm going to coat the exposed wood with some gel coat before I mount everything for good.
    The SeaStar Pro/Tournament system is in, and most all the wiring is in. Things are starting to move quickly now.
    Attached Thumbnails Attached Thumbnails IMG_6994.jpg   IMG_6995.jpg   IMG_6996.jpg   IMG_6999.jpg   IMG_7001.jpg
  9. Likes Merc 2.5, LakeFever, loop, Hippie459MN liked this post
  10. #366
    Mar 2004
    Brooklyn Park, MN
    now that is a fuel tank!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  11. Likes tnelsmn liked this post
  12. #367
    Minneapolis MN
    Welding/metal fab is my trade and what I did for a living for the last decade. So this was part of the build where I actually knew what I was doing.
  13. #368
    Jun 2018
    Floating around
    Speedglas! Winning lid there. You use the adflo stuff too?
  14. #369
    Cudjoe Key FL
    Any thought of using angled bezels for gauges to help you see them easier?
  15. Likes tnelsmn liked this post
  16. #370
    Minneapolis MN
    Lake Fever, been wearing a Speedglas helmet my entire career. adflo? Not familiar with that...
    Sonic, the thought did cross my mind more for a looks aspect. The boat is so small I don't think I'll have trouble seeing the gauges. The bottom right is already blocked by the steering wheel. That is something that could easily be added later if need be.
  17. Likes sonicss33 liked this post
  18. #371
    Jun 2018
    Floating around
    Speedglas have the adflo attachments for papr clean air supply. They work great! Works a bit like air conditioning in the heat too.
    anyways not to sidetrack here your rig is looking fantastic. We are inching very close to starting ours. Can hardly wait
  19. Likes tnelsmn liked this post
  20. #372
    Minneapolis MN
    Oh I see. Nope never used one of those. I did 90% TIG at my last job and the shop had AC. So never really needed it.
  21. #373
    Jul 2012
    Lufkin, Texas
    Those auto dark hoods (yes, even speedglas and other high end ones) bother my eyes no matter how I adjust them. I'm a "nodder" anyway, old habits die hard...
    Josh Peterson
  22. Likes LakeFever, tnelsmn liked this post
  23. #374
    Shreveport, La.
    I love this thread. Very informative and lots of pictures. Being the same color as my old 1981 Viking don`t hurt either.
  24. Likes tnelsmn, Gw1nels175 liked this post
  25. #375
    Jun 2018
    Floating around
    tnelsmn can you tell me the outside to outside spacing of your trailer bunks? Sooner the better Im in the middle of trying to configure bunks with no boat to measure. Thanks a TON, i hope your near the boat today lol
  1. 1978 vking rebuild
    By rjdubiel in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2021, 01:35 PM
  2. complete rebuild Monster Viking
    By primerate2 in forum Appearance Mods
    Last Post: 10-25-2011, 02:14 PM
  3. Blue 1978 viking lansing, mich
    By 200VEGAS in forum General Boating Discussion
    Last Post: 08-07-2010, 09:04 AM
  4. 1978 Galaxy rebuild
    By Auggie2612 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-25-2009, 10:32 PM
