Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 101
  1. #76
    Feb 2005
    Rehoboth, Ma
ID:	472491this one magnet has a crack, do you think it is still usable? currently replacing stator and SW boxes due to no spark in all cans
  2. #77
    Feb 2005
    Rehoboth, Ma
    flywheel number is 271-817632 c-1Click image for larger version.
  3. #78
    Apr 2017
    pa
    5 Post(s)
    that looks like a 40 amp cast flywheel. probably why you don't have spark if you have 16 amp stator
  4. #79
    Apr 2017
    pa
    5 Post(s)
Name:	flywheel 16 amp.jpg
ID:	472494 16 amp
  5. #80
    Apr 2017
    pa
    5 Post(s)
  6. #81
    Feb 2005
    Rehoboth, Ma
    My magnets are 3/4 in height, I believe the 40 amp are over 1.0 inch in height.
  7. #82
    Sep 2017
    Ashland city tn
    Quote Originally Posted by dave22 View Post
    A 98 sport jet 175 had a 40 amp stock from merc , if it has a 16 it has had the ignition system changed , do you have 2 regulators on back motor by heads?
  8. #83
    Apr 2017
    pa
    5 Post(s)
    Maybe sport jets are different. I have never seen a cast 16 amp flywheel.
  9. #84
    May 2014
    Livingston, Louisiana
    I had a cast 16 amp, I’ll check and see if I still have it and if all magnets are in good shape, if not you can use a flexplate one in its place. Going to be hard to find, the one I had was the only one I have ever seen.
  10. #85
    Apr 2017
    pa
    5 Post(s)
    I would run flexplate flywheel over cast if I had the choice. Little lighter. I have a 9/16 flexplate if interested. $35 plus ride
  11. Likes FORBESAUTO liked this post
  12. #86
    May 2014
    That’s the reason I had one laying around, because I replaced it with a flex plate. It seems as though mine has a cracked or repaired magnet also. The way the magnets are just glued on and hanging out there with no protection makes them prone to damage, kinda of cruddy design. Was only holding on to it because I felt it was unique being it was the only one I had seen
  13. #87
    Feb 2005
    Rehoboth, Ma
    Thanks all, forbeauto - its definitely a cast 16 amp FW, I would be interested in yours. or just some magnets..
    Bullet123 - got a pic of the flex plate design FW - what else would have to changed?
    Do you think this would work with that one cracked magnet?
  14. #88
    Apr 2017
    pa
    5 Post(s)
    I wouldn't bother trying to fix it. Flexplates are lighter and seem to last forever, but that's up to you
  15. #89
    Feb 2005
    Rehoboth, Ma
    only one regulator,
  16. #90
    Feb 2005
    Rehoboth, Ma
    Bullet123 - does the flex-plate just bolt on using my existing stator and trigger...send pic when you-have a chance - I am interested
  1. fall garage cleanout
    By carguylsx in forum Misc. Parts and Accessories
    Last Post: 11-14-2014, 07:32 PM
  2. Shop cleanout...some 260 parts....
    By h2oskiier30 in forum Misc. Parts and Accessories
    Last Post: 08-07-2013, 03:17 AM
