Results 16 to 30 of 45
08-09-2020, 10:12 AM #16
The Historic Photo Master
- Jan 2004
- Florida
- 38,649
- 78
- 1764
- 384
- 20386
- 4 Post(s)
08-09-2020, 10:58 AM #17
Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Sounds like you are an old school Ford guy too.......Mr Fujimo!!!! How else would you know all that?
08-09-2020, 02:37 PM #18
Havent looked at seafoam MSDS in years but is it mostly alcohol/methanol/?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
08-09-2020, 10:01 PM #19
Here's the basic recipe for SeaFoam, and considerably cheaper. All the componant ingredients are available with a visit to just a couple stores in town. Maybe Wally's and a Sherwin Williams or even Lowes. You'll be able to find the ingredients easily enough though
Found on the internet under 'Homebrew SeaFoam recipe', I'd site the author, but he/she seems to be FAR removed by now as this has probably made the forum rounds an alot of motorhead sites.
It's very cheap and easy to make at home
25% Cleaner>Naphtha
60% Stabilizer>Kerosene
15% Oxygenate> Isopropyl Alcohol (common Rubbing Alcohol)
Other Commercial Brands such as Chevron Techron Concentrate are 100% Cleaner.
Majority is Naphtha,,,along with Stoddard Solvent,Benzene,Xylene,etc.
You can Substitute Seafoam's 15% IPA for Toluene and get better results,,,most paint stores have it.
ALL the Products are merely a variety of Blends of generic,,bulk commodity petrochemicals.
They are simply bought by the barrel,,,,mixed together in various ratios,,,,Bottled>Labeled>Sold
SeaFoam for example,,
It's sells for about $8 USD for 16oz.
$64 USD per gallon
"Naphtha",,,2 Bottles @ $1 ea = 1/2 gallon
"Kerosene" 3 Bottles@ $1 ea =3/4 gal
"IPA" 2 bottles for 1$ = 1/4 gal
$6 for 1.5 gals
For "GENERIC ,Homemade Seafoam"
versus the
$64 USD per gallon
for actual,,name brand Sea Foam
It's not so much the point that it's only 1/10 the Cost,,,
it's that homemade blend allows for ,,,not just Enhancement but even Exaggeration of the Beneficial Properties of the Additive Mix.
For example :
Skip the Rubbing Alcohol,replace it with Acetone,,,Same Price.
Makes engine Start much better in Cold Weather,,,SOMETIMES improves fuel mileage,,,is Less Corrosive,,,and acts like a Cleaner Itself.
And,,it gets added in at much,much lower doses.
Or,,,add a $5 pint of Toluene in lieu of a quart of Kerosene
Or ,,1$ Quart of Auto Trans Fluid,to make Mega Stabilizer.
Or,to add to Crankcase---it sometimes Smokes a bit.
But I just FEEL better Cleaning internals with a premium LUBRICANT as the engine runs,,,rather than all Solvents.
Or if You would rather buy a Commercial Product and can Not find Seafoam
Chevron Techron is much,much More Powerful Cleaner by volume.
It will work at minimum,,,,better and faster and on a wider range of Fuel Deposits .
But ya should really only use it in fuel,,not in Crankcase.
It's too aggressive a cleaner and not made for such use.
Beyond Those particular products,,
Anything labeled "FUEL INJECTION" cleaner is typically going to be Higher Concentration of appropriate CLEANERS,,, than products labeled as "Carb Cleaner" or "Gas/Fuel Treatment"
The Later 2 products Have been enriched during last Decade or so,,
So the Differences in all the Variety are Not as Great as they were 15~20 years ago
If Sea Foam is Not available,,
Chose Anything labeled as FUEL INJECTION cleaner and it will do about as good a job as Sea Foam in your Tank, injectors, varnish, carbon etc in Intake tract, Valves and combustion chamber.
All more/less same stuff.
CLEANERS,,,have More Cleaner and Less Stabilizer than SeaFoam.
You are currently going through Fresh Petrol,,,so Ya do not Need the hi-dosage Stabilizers at this point.
Especially when trying to CLEAN the fuel system.
You need the higher dose Cleaner.
08-09-2020, 10:21 PM #20
Damn good & ACCURATE info, Chaz
AIRWALK
gettin' old ain't for sissies
08-09-2020, 10:25 PM #21
08-09-2020, 10:28 PM #22
About the wintergreen oil, go to the pharmacy & pick up a small bottle. Next time you have a seized, rusted stuck anything - a very few drops & an overnite soak will amaze you. Works better than anything you buy in a spray can. The man that used to make house calls to work on our boat in the late '50s showed me this trick.
AIRWALK
08-09-2020, 10:31 PM #23
08-09-2020, 10:47 PM #24
I only need my glasses to see what I'm lookin at ..
08-10-2020, 07:35 AM #25
- Jan 2004
- Florida
- 38,649
- 78
- 1764
- 384
- 20386
- 4 Post(s)
08-10-2020, 12:34 PM #26
Good info on the SeaFoam Chaz. I'm curious how he got the ratios as usually that's not on the MSDS.
www.InjectorService.com
Call/Text - 204-326-0390
08-10-2020, 02:27 PM #27
Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Chaz, have you ever mixed your own ratios to clean up the rings and combustion areas in an outboard...............before and after kinda stuff?
I will be writing down those ratios for myself in the future..........great stuff.
08-10-2020, 02:38 PM #28
Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
08-10-2020, 03:27 PM #29
Screaming And Flying!
- Miami,Fl
- 7,055
- 151
- 83
- 1452
- 381
Fuji you forgot the 312 interceptor my favorite car was a 1960 ford starliner tried to save money and put a fenton shifter in it and every time I shifted real hard had to go under the car and jiggle the linkage.
08-10-2020, 04:31 PM #30
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Works pretty good in the gas and oil of my opti. I did switch to Techron though.
if you feel lucky you can run a tank of alcohol gas for little to no extra cost just don’t leave it in more then a week. Not for premix though just oil injected (preferably separate not premix in the vst)
Skip acetone if you have any plastic in the fuel system it eats most kinds.'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
Marvel Mistery Oil
By redgambler in forum Technical DiscussionReplies: 7Last Post: 03-03-2009, 10:21 PM -
Marvel Mystery oil
By baddjonny in forum Technical DiscussionReplies: 5Last Post: 08-07-2003, 11:31 PM -
Marvel Mystery Oil
By Joe L. in forum Technical DiscussionReplies: 5Last Post: 07-22-2002, 10:08 PM -
Marvel Mystery Oil
By Way2Fast in forum Technical DiscussionReplies: 8Last Post: 03-23-2002, 11:12 AM
