Results 1 to 9 of 9
07-26-2020, 11:08 AM #1
So what is involved in putting sportmaster gears in an xr4/xr6 gearcase?
I see that the stock xr pinion/driveshaft uses the inline spline pattern. The pinion bearing surface is larger diameter on the driveshaft for the regular v6 full size gearcase, and I don't think it can be turned down to fit the xr gearcase, as I assume that the surface is hardened. I know I would have to trim down the diameter of the gearset from a regular v6 case to fit the xr gearcase. So I know it's been done, but how? Thanks!!!
07-26-2020, 12:56 PM #2
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,984
- 679
- 1076
- 1917
- 7936
- 4 Post(s)
Charlie,
Jim Ruck did one for me years ago. You might want to call the guy that took his operation over and ask him for details (he witnessed a bunch of them being built and was hands on with Jim).
mrcrsr liked this post
07-26-2020, 01:35 PM #3
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,652
- 301
- 279
- 1791
- 1275
Your best bet at this point us probably to pay up for one of the surviving Steckbauer (sp?) cases. You can probably find one if you post on one of the FB (
) boat groups like "high performance props and more." Prepare to break out $$$$...
07-26-2020, 02:59 PM #4
Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
You want the XR6. The pinion bearing bore in the XR4 is wrong. If I remember right the pinion bearing from a big case will press in the XR6 without mods. Might pm Cody Tarver on FB. I think he cuts gears. Should know the in’s and out’s
Erik Kiser
07-26-2020, 06:37 PM #5action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
07-27-2020, 06:38 AM #6action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
07-27-2020, 11:06 AM #7
Charlie 93 brochure listed 1:78 and 1:87 case option 95 only 1:87. 92 was first year of XR6.
07-27-2020, 04:10 PM #8
I have a couple of good xr4 cases, I may take a look at what is involved to bore it for the xr6 pinion bearing. It would be easy enough to turn the v6 driveshaft in the lathe to change the upper bearing height for the shorter xr4 housing. Finding an xr6 would probably be a good luck deal
07-27-2020, 04:25 PM #91980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
2.5 Sportmaster gearcase 1.87 gears
By Mercit in forum Lower UnitsReplies: 2Last Post: 07-18-2017, 05:29 PM -
Putting a blowout ring on a sportmaster???
By h2oskiier30 in forum Technical DiscussionReplies: 2Last Post: 09-05-2010, 01:25 PM -
Help putting gearcase on inline 6...
By cm21 in forum Technical DiscussionReplies: 13Last Post: 07-07-2003, 03:44 PM
