Results 1 to 13 of 13
    Jun 2020
    ontario , canada
    74 135 strangler
    Anyone got any info on this 135
    strangler looks like every other v4 I have. I'm restoring a 1974 baja ski boat and was gonna use this being as its the same year or would I be better off just putting my 115 intruder
    Attached Thumbnails Attached Thumbnails strangler4.jpg   strangler (1).jpg   strangler2.jpg   strangler 3.jpg
  2. Likes Instigator, mrichartz liked this post
    12 Post(s)
    Great motor.
    Easy to work on, parts are cheap, and perfect for your project.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
    Sep 2008
    Mass
    Nice motor. You can modify to run and 80' tilt and trim. A huge improvement.
    your late model motor, put the other on a stand and restore it
    MIAMI FLORIDA
    Agree with above don't leave the old girl there to end up at a scrap yard.. Cool looking old motors but they were the same as a standard 135 except for the decals, the top of the cowling and gearcase should be blue.
    Jun 2020
    ontario , canada
ID:	468428 looks like someone just painted it white. Someone just dropped it off there its on a stand now. But sadly I'm building a 14' tunnel so its a little big lol the hulls built around a 3 cylinder. But then again maybe not
    5 Post(s)
    or did the blue wear off the white...
  9. #8
    Jun 2020
    ontario , canada
    Maybe lol I just seen a post that this motor weighs 256 lbs with the power trim. Any truth to this? What foot options did it have. And i guess this one didn't have the high compression heads just the super strangler?
  10. #9
    Feb 2005
    seattle
    use your 115 which is a 140 at power head. some of the early 135 had crank balance issues and could get more than 115 hp at head.
    add then exhaust web cutout to increase the headm hp by 5hp.
  11. #10
    Sep 2008
    Mass
    I built a pretty cool 73 135. New trim conversion. Biggest carbs. Reed's. Ported intake. There's a better intake I like too. I ended up melting a Piston because the compression was so high. Needed 93+ pump at least or mix in some race fuel. 100LL aviation would be perfect actually. I'm rebuilding it on a 76 big bearing crank and block.
  12. #11
    Jun 2020
    ontario , canada
    Nice! Did you use the heads and carbs from super strangler? Do you have porting specs on these old crossflows
  13. #12
    Aug 2019
    Canada
    Things I've compiled. Measured from top of the jug. Keep in mind I found these measurements on different threads but they do carry a similar theme. I don't want to be responsible for someone butchering their motor.
    Port timing
    V4 90hp
    In 2.170
    Ex 1.805
    .365
    V4 140
    In 2.1
    Ex 1.76
    .34
    V6 200
    In 2.125
    Ex 1.625
    .5
    V6 ccc
    In 2.0
    Ex 1.575
    .425
  14. #13
    Jun 2020
    ontario , canada
    No problem what rpm did you 140 run at? I also hear the 73 had the highest compression in stock form
  1. 100hp Super Strangler???
    By Smoking Joe in forum General Boating Discussion
    Last Post: 10-08-2016, 07:53 PM
  2. OMC Strangler
    By lilwhirlwind in forum Technical Discussion
    Last Post: 10-08-2014, 09:14 PM
  3. Strangler or Twister!!!!!!
    By Guy Hanson in forum Outboard and Racing History
    Last Post: 09-16-2008, 06:30 PM
  4. V8 tunnel! and Strangler
    By Guy Hanson in forum General Boating Discussion
    Last Post: 01-22-2007, 07:01 AM
  5. Twister 2 or Super Strangler
    By KG4 in forum General Boating Discussion
    Last Post: 08-04-2002, 07:59 PM
