Results 1 to 15 of 18
    May 2020
    1994 2.5 175hpxri fuel injection
    What’s a fair price for a 1994 2.5 175hp xri fuel injection, guy says everything works as it should and has 120psi on all cylinders, I think it comes with controls also. Anything else to look for on this motor if I go take a look at it? Thanks.
    Jun 2009
    Bristol, Connecticut
    Maybe 2500-3 if clean
    Jun 2009
    Quote Originally Posted by Jmr1974 View Post
    Post pictures
    May 2020
    Quote Originally Posted by Aaronhl View Post
    Post pictures
    I can’t seem to get pics from my iPad right now but looks pretty decent from the pics, lower unit is clean, not all chipped and beat up. The motor clamp looks Like it’s missing some paint or is a little corroded. It’s about a 1hr drive for me which isn’t bad at all.
    Jun 2009
    Do you have the serial number?
    May 2020
    Here’s the motor. Only thing I don’t like is what looks like corrosion on the motor bracket, it is 26years old tho.Click image for larger version.
ID:	467828Click image for larger version.
ID:	467824Click image for larger version.
ID:	467825Click image for larger version.
ID:	467826Click image for larger version.
    Attached Thumbnails Attached Thumbnails E9198B82-D909-4E92-B362-0199B81E5531.jpg
    May 2020
    Also waiting to here back on the serial#
    Jun 2009
    Yea they arnt going to be perfect being as old as they are, I wouldn't let a little rust scare you unless the tiller arm under the cowl is completely eaten through
    What $$$$ is he asking for it?
    May 2020
    3500.00....
    Sep 2017
    Ashland city tn
    3500.00....
    I would say that's the max (high end) of price range for that motor and condition ,, usually can get nice 200 for that also , not bad price but not stealing it imo , but if his askin price is 3500 then he prob has little wiggle room
    May 2020
    Quote Originally Posted by Merc 2.5 View Post
    That’s kinda what I figured also, a tad on the high side. Earliest I can look at is Friday afternoon, he’s out of town till then. He also has a 1997 175 for sale for 3600.00 without controls. Same shape. Not sure if one’s better than the other only being 3 years newer, I like the cowl style better on the 94 tho...
  12. #12
    May 2020
    Were there any difference or improvements made from the 94’ to the 97’ or did just the styling change? Would one be better than the other if everything is mechanically sound on both?
  13. #13
    Sep 2017
    Ashland city tn
    Prob no diffrence except the cowl , but merc did sum funny stuff
  14. #14
    Apr 2017
    pa
    5 Post(s)
    97 will probably have 2 wire trim (relays instead solenoids) and fuel pump built into vst. Neither motor is worth more than $2500 IMO.
  15. Likes Aaronhl liked this post
  16. #15
    May 2020
    Yep, I know the prices on these are pretty stiff, it hasn’t been that easy to find one in the 2500 range tho, maybe he has some wiggle room. All he can say is no and I keep shopping. I doubt he’ll come down to 2500.
  1. Replies: 16
    Last Post: 10-08-2018, 01:47 PM
  2. Mercury Tech: replacing fuel lines on 1994 200 xri
    By floridascuba in forum Technical Discussion
    Last Post: 06-16-2018, 11:24 AM
  3. 1994 mariner 200 efi fuel problems. Please help
    By Brocke21 in forum Technical Discussion
    Last Post: 05-26-2018, 05:21 PM
  4. Mercury Tech: convert 1994 carbed 200 2.5 to fuel injection?
    By camaroguy71 in forum Technical Discussion
    Last Post: 11-20-2012, 06:26 PM
  5. Replies: 7
    Last Post: 01-28-2011, 08:21 AM
