Results 1 to 13 of 13
    Aug 2005
    West Allis,Wisconsin
    225 PM water getting in #6 cyl.
    Getting water in #6 cylinder on a 96 225 PM Replaced the head gasket and did not fix it. 2 hours on the fresh engine. Any ideas, got me puzzled? Noticed it yesterday after I pulled plugs to check color. Definitely water, not alot though. Can see water on the plug and in the cylinder when I had the head off.
    Ran it on the hose and same thing. Also seems to have high water pressure.
    Seemed ok on the hose Sunday, Monday on the lake when I checked the plugs I saw the water. Then I started it and went to put it on the trailer notice the high water pressure.
    May 2017
    Ca
    How high of water pressure?
    Aug 2005
    10 psi idle and 25 psi at 6000 rpm.
    May 2017
    Ca
    That’s exactly what I’m seeing on mine right now but haven’t seen water in the cylinders. Just pulled my powerhead to check the exhaust plate and don’t have any clogs
    May 2017
    Ca
    #6 is bottom left cylinder. Pull the exhaust divider and make sure water isn’t leaking and getting sucked in. Could also suck water in from base gaskets below being the bottom cylinder
  6. Likes TEXAS20225 liked this post
    Jul 2010
    Ankeny Iowa
    How does the tell tale stream look? I had a crack in a combustion chamber allowing water into the cylinder, but the indicator that I had an issue was the the pulsing from the tell tale.
    Jul 2002
    FT WORTH, TEXAS
    exhaust divider pull it !!! ive had same problem several times started using a sealant along with new gasket
  9. #8
    May 2017
    Ca
    Make sure you clean the gasket surfaces of the block and divider plate super good and clean with brake cleaner to get any oil
    and grease off before re assembly
  10. #9
    Aug 2005
    Pulled divider, cracked on bottom.
  11. #10
    May 2017
    Ca
    Divider was cracked?
  12. #11
    Aug 2005
    Yes exhaust divider plate is cracked all the way around on the bottom. Spraying water into #6 cylinder.
  13. #12
    May 2017
    Ca
    Damn gnarly. At least you found the issue. Was the motor still running good?
  14. #13
    Aug 2005
    Still running ok. Have to figure out high water pressure yet. Sucked up some sand last Sunday. Think I will have to pull the power head and clean out adapter plate.
  1. Replies: 54
    Last Post: 09-23-2019, 11:00 AM
  2. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  3. Mercury Tech: Looks like water in fuel but no water in water separator. Confusing. Any ideas?
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 07-23-2014, 02:05 PM
  4. warm water cold water salt water???
    By Hottrucks in forum General Boating Discussion
    Last Post: 11-03-2008, 02:38 PM
