Results 46 to 60 of 88
Thread: High water pressure 225 promax
05-27-2020, 08:22 PM #46
05-27-2020, 08:24 PM #47
05-27-2020, 08:25 PM #48
5000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
05-27-2020, 08:26 PM #49
5000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
05-27-2020, 08:37 PM #50
05-27-2020, 08:39 PM #51
5000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
05-27-2020, 08:54 PM #521980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
05-27-2020, 09:01 PM #53
5000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
05-27-2020, 09:07 PM #54
05-28-2020, 05:08 AM #55
Not necessarily saying to replace it but at the very least I would take pump apart and double check everything especially if all else checks out.
Dave, do not think so because the PM's came with them. They there to build heat.
Funny is I had a discussion with Tommy tljkw awhile back to see if he knew why the production 200 motors never came with them but we could not come up with an answer. I put them in especially up here in the colder waters and most definitely with a 1pc plate application on all steel sleeve motors.
Bunger, I would agree with Dave to pull heads a small rock or debri in even the rectangular circulating slots or elsewhere could make things act up.
Is you gauge steady or bouncing pressure?
Below is a picture how they came from Mercury.
05-28-2020, 05:26 AM #56
Tux, are ya sure tha pro max came with those???.. i only remember tha nic/chrome hi po motors havin' 'em?.. but ya right.. will not have anything ta do with pressure.. hope he finds something soon 'fore he goes off ona an unscheduled trip!!!..ha.
Dave Strong liked this post
05-28-2020, 05:33 AM #57
05-28-2020, 05:39 AM #58
I had a 2.4 200 that I had really high pressure and I couldn't get it down to save my life , motor wasnt runnin hot or cold , so I just ran it. Not sayin that's what u should do tho
05-28-2020, 06:02 AM #59
5000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Gotcha. I have a set of .75 head gaskets to replace them
with. No idea what thickness is on there now. Are those ok to run? Maybe but the compression sup a few psi is all right? I typically run a mix of 100LL and 91 pump anyways
did you guys see the pics of my number 2 plug and the left bank being washed and cleaner than the right bank? Any ideas
05-28-2020, 07:00 AM #60
Not sure if sumone answered this but ur stats will control idle temp and poppet takes over to control temp when running.
I dont no enuff bout efi to comment on plug. Ecu driver fires 2 injectors I believe , so that would make me think there would b 2 dark ones if it was ecu thing?Last edited by Merc 2.5; 05-28-2020 at 07:04 AM.
High Water Pressure After Changng Water Pump
By maineidyl in forum Technical DiscussionReplies: 8Last Post: 08-11-2018, 05:10 PM -
Mercury Tech: High water pressure & low water temp
By njj502 in forum Technical DiscussionReplies: 158Last Post: 10-19-2017, 03:00 PM -
promax high water pressure
By ActivatedSludge in forum Technical DiscussionReplies: 23Last Post: 10-25-2014, 08:06 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM
