Results 1 to 7 of 7
    Aug 2005
    Knoxville , TN
    Putting a clamshell cowl on a promax.
    I've read the threads on it and some say it couldn't be done, even asked a few questions myself. Finally did it the other day and it wasn't really that big a deal.
    The biggest thing I realized is that I could retain the 40A charging system. The only thing you can't do is run the flywheel cover, but I can't see a need for it other than the timing needle. There is ample room for the flywheel, no chance of hitting the cowl.
    I fabbed some brackets for the back strap, and I had an idea or 2 that didn't work, so I have some extra holes in a couple of them. Nobody will see it but me anyway. That lined up real well and the cowl closed nicely. The front piece where the rigging and fuel line go through bolted right to the bottom of the air box using the same spacer washers that were on the bottom of the carbs on the other motor. The top 2 ears where the pins on the inside front of the cowl go was also a direct bolt on. Unbolted ecu, took spacer washers off, then put the ear bracket where the spacers were and put ecu back on. The only thing that took a little extra figuring was where to put the voltage regulators and trim solenoids. For the regulators I made a couple plates that bolted to the top of the motor where the alarm module was and to the side where the idle stabilizer was, then bolted the regulators to the plates. I took a piece of angle and bridged across using the old oil tank bolt holes and bolted trim solenoids there. That's about it. Most of the pictures are in progress pics, it’s much cleaner and tidy now.
    It took me a little time figuring as I went, but when the cowl's on you'll never know anythings different. Hope this helps anybody who needs it.
    https://youtu.be/PTc3aKgOJxE
    Attached Thumbnails Attached Thumbnails 95090625_639677089947108_4405638767742812160_n.jpg   94884178_1561542824021802_7378421349699551232_n.jpg   94583498_852387135172100_8927688874537254912_n.jpg   94529035_906177276498667_3078938337969438720_n.jpg   95416233_536748747270703_2011764871879720960_n.jpg
    94477507_852325351922646_5623430187078123520_n.jpg   94387663_544010143181471_5788212427069849600_n.jpg
    1995 Allison XB-2003, 225 Promax
    2002 Trans Am, pulls the boat fine.
  2. Thanks tnelsmn thanked for this post
    Not much that can not be done with a little thought, engineering and some work....... Like the cowling!
  4. Likes mrichartz liked this post
  5. #3
    Jul 2005
    AZ
    Never say Never... Looks goods
  6. Likes tux974 liked this post
  7. #4
    Sep 2017
    Ashland city tn
    Nitro rat did it to a 2.5 carby , looks good
    Minneapolis MN
    Was hoping to save my old clam shells when I eventually get a ProMax! This is great news!
  9. Likes mrichartz liked this post
  10. #6
    Sep 2017
    Ashland city tn
    Was this the 200 clam or the 150 175?
  11. #7
    Aug 2005
    Knoxville , TN
    Quote Originally Posted by tnelsmn View Post
    That's pretty! Blue stripe with red numbers is one of my favorites.
    Quote Originally Posted by Merc 2.5 View Post
    135. Has the 2 metal latches in front, not the plastic ratchet piece.
  12. Thanks Merc 2.5 thanked for this post
    Likes tnelsmn liked this post
  1. Putting 200 stuff on 225 promax?
    By rusty202 in forum Technical Discussion
    Last Post: 05-26-2005, 06:07 AM
  2. Clamshell Cowl?
    By HydrostreamDave in forum Technical Discussion
    Last Post: 01-09-2002, 10:16 PM
