Results 1 to 15 of 28
    Sep 2017
    Ashland city tn
    Lower unit seals
    I got sum small rope caught up behind prop and killed seals , I've been lookin on promarine web site but not real clear on which I need to get. Lower is from a 2.4. Ratcheting if it makes a difference. I just wanna order em once lol. Wanna buy the seal kit but it comes with water pump stuff that I dont need , (just got complete kit) lower didnt leak at all b4 prop shaft seals got tore up. Hoping to pull em and install em without pulling carrier. Any help with part number for seals be great. Or if sumone has couple extra they wanna sell. Thanks
  2. Likes Baker343 liked this post
    SW Florida
    How do you plan to get them out without removing carrier? Boats.net or Marineengine.com and enter your year, make, model... OR Local shop who has been good to you that you'd like to support during these tough times?
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
    Sep 2017
    Ashland city tn
    I dont do shops , theres not any gud honest shops close last time I drilled 2 small holes n seal and put in 2 long screws and the use a pry bar on the screws and popped rite out, never touched the propshaft
    Jun 2012
    Indiana
    Should be able to buy just the seals. I would remove carrier to replace them. It takes a special tool to install them. Not sayin you cant get it done without, but the tool sets them at the proper depth.
    Sep 2018
    Massachusetts
    May 2014
    Livingston, Louisiana
    http://parts.promarineusa.com/CGI-BI...42602B+M50+ENG
    Get ya two of these. Don’t use the “outer line cutter seal”, especially if your are surfacing it. It will cut a groove in propshaft. Stock applications it’s ok. I personally always use the two “normal” seals, and always pull carrier to make sure I don’t scratch either surface and get em in straight and at proper depth. Plus like the idea of seeing how everything is holding up in there. It can be done without, just super careful and cautious.
  8. Likes TEXAS20225 liked this post
    Make sure you order the correct size. Fat shaft or small shaft. There is a slight diffrence. And 3 seals WILL fit in there. And I personally fill the seals with DOW 111 lube.
    Sep 2017
    Ashland city tn
    I haven't tore down a lower yet , is the reason I'm tryin replace without tearing down. Guess I'll order the carrier tool also and take it out. This shouldn't require any shimming ??
    Jul 2002
    FT WORTH, TEXAS
    its consumer 1 3/16 dia shaft just like millions of others ,1 1/4 hi-pos are only in cle's, torqmaster's and sportys do your self a favor pull the carrier NOTE THE WAY THEY COME OUT
    Jul 2012
    Lufkin, Texas
    If you take the carrier nut off you can replace it with the thick one. It helps prevent distortion when surfacing. Haven't bought one in a while but IIRC they used to be 50 or 60 bucks...
  13. Likes TEXAS20225 liked this post
  14. #11
    Sep 2017
    Ashland city tn
    Thanks tex. was hoping u respond. I'll pull it, but if I got questions I'm callin u. Haha
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by TEXAS20225 View Post
    If you go back with 3 seals put the first one lip in to keep oil in and the next two lip out to keep out water!
  16. #13
    Sep 2017
    Ashland city tn
    Ya its sumthin I been procrastinating on. I need get my hands in lower any way. Least it ain't salty
    Should only have 2 seals tho? U sayin cram 3 in it?
  17. #14
    Jul 2012
    Lufkin, Texas
    They come with 2, 3 will fit. If you run 3 they probably won't line up with the existing wear marks on the shaft either...
  18. Likes XstreamVking, TEXAS20225 liked this post
  19. #15
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by Merc 2.5 View Post
    Won't affect the shims. Might need a slid hammer puller to get the carrier to slide out. Don't lose the little key.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  1. Lower unit seals Help
    By 205pro in forum Technical Discussion
    Last Post: 08-25-2014, 08:26 PM
  2. Replies: 19
    Last Post: 03-14-2011, 02:49 PM
  3. Lower Unit Drain and Vent plug seals
    By wj225 in forum Technical Discussion
    Last Post: 02-14-2011, 03:29 PM
  4. Mercury Tech: Lower unit seals?
    By CSD23 in forum Technical Discussion
    Last Post: 07-22-2010, 03:14 PM
  5. Lower Unit Seals and Water Pump...
    By usamarshal in forum Technical Discussion
    Last Post: 01-25-2007, 11:45 AM
