Results 16,996 to 17,010 of 28396
Thread: Mercury Through The Years...
04-08-2020, 01:40 PM #16996
Agree on 24 volt as mine was slow, but useable for just missing around the lake. Even then, running a 14x28 2 blade cupped, surfaced prop (trashed two gear cases expansion) it was all on the bow until grabbed, then sit back and wait. Boat was a beast, but zero hole shot! Nice rooster tail though! Got me laid though girls wanting a ride! Fun times in the 70's!
Dave Strong liked this post
04-08-2020, 02:39 PM #16997
The Historic Photo Master
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-08-2020, 04:44 PM #16998
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-08-2020, 04:56 PM #16999
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-08-2020, 05:52 PM #17000
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-08-2020, 07:23 PM #17001
5000 RPM
- May 2003
- Fond du Lac WI
- 815
- 18
- 85
- 72
- 407
Robby321 liked this post
04-08-2020, 07:44 PM #17002
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
yup, they were plumbed opposite of factory, as used on a factory inline pleasure motor. they were available in a 3/4 diameter shaft, or a 1'' diameter shaft. different seal kits of course. back in the day, before trim was common, people jerry-rigged them to use on a few different things. trimless volvo outdrives come to mind. bracketry was made for them as well, utilizing the merc o/b cylinders.
04-09-2020, 02:23 AM #17003
When i cut my mid down to 12 inch had to remove the trim mounting pin from the swivel.
Rigged up a internal with a single standard ram.
With just the one ram it is faster with 12volts
Had to limit the travel in and out but worked great.
Dale
04-09-2020, 08:32 AM #17004
5000 RPM
- May 2003
- Fond du Lac WI
- 815
- 18
- 85
- 72
- 407
04-09-2020, 09:41 AM #17005
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
...There were a handful of racers making their own versions back then...not just Petty and Merc...
04-09-2020, 10:38 AM #17006
6000 RPM
- Nov 2006
- 1,756
- 18
- 182
- 86
- 783
- 45 Post(s)
Single Ram Set-Ups - Homemade
I saw a lot of these trim set ups in Sport J. How did you attach the ram to the swivel bracket casting? Weldment? Interesting side note: we took production trim rams and cut off the offset knuckle to use on T2s and Champ mid sections rather than using Merc HP rams. You had to watch the plumbing hook ups though. If you were in a hurry and got it backwards, it would bleed "in" under power. I learned this the hard way in Sport J and barrel rolled in a turn (LOL).
04-09-2020, 10:47 AM #17007
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-09-2020, 11:22 AM #17008
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
04-09-2020, 11:35 AM #17009
5000 RPM
- May 2003
- Fond du Lac WI
- 815
- 18
- 85
- 72
- 407
04-09-2020, 11:44 AM #17010
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20524
- 4 Post(s)
we all can bernardo. cut the grass when you get home from Englewood.
Mercury racing line-up thru the years
By triplestroker in forum Outboard and Racing HistoryReplies: 13Last Post: 05-08-2014, 04:31 PM -
What years were 2.4 & 2.5 blocks built by Mercury?
By Knothead in forum Technical DiscussionReplies: 28Last Post: 06-18-2013, 06:22 PM -
1976 Mercury 65 hp first start in 12 years
By DaveS8984 in forum Technical DiscussionReplies: 8Last Post: 07-26-2011, 06:07 PM -
Looking for an old Mercury commercial, about 10-11 years old
By Ron V in forum General Boating DiscussionReplies: 0Last Post: 04-27-2006, 08:31 PM
