Results 1 to 15 of 19
    Jan 2005
    New York
    Rub Rail Hydrostream venus
    anyone know where to look for that crazy rub rail on hydrostreams.
    Patriot Missile
    May 2001
    Charlotte, NC
    Call Allen at Rubrail.com
    PARADISE /Naples
    Minneapolis MN
    The original aluminum style?
    Jan 2005
    New York
    Yes
    Patriot Missile
    Minneapolis MN
    I don't believe you can buy that style anymore. I ended up having a local fab shop form some out of sheet metal. It looks the same from 5'. I've only had them do a prototype so far and haven't done the whole boat yet. The trick is going to be forming it around the hull. I could cut off a chunk and mail it to you so they could pull measurements if needed.
    Original on the left, new on the right.
  7. Likes hydroo liked this post
    PARADISE /Naples
    Where there is will there's way
    J channel
  9. #8
    PARADISE /Naples
  10. #9
    May 2001
    Charlotte, NC
    You can’t buy direct from taco marine but I bought Taco rubrail for my old 69 CM project thru rubrail.com. Taco is the only place that I could find to match the original aluminum rail. Might be worth calling them.... One thing to watch out for is they can’t ship FX/UPS if the piece is longer than 10’ and truck freight is $$$.
    Attached Thumbnails Attached Thumbnails 0DEBA0F3-BB14-46E1-8020-553DE23D1B62.png
  11. #10
    PARADISE /Naples
    I believe they are at least 20' I use to drive to Miami with a trailer.
  12. Likes SCT liked this post
    Jul 2012
    Lufkin, Texas
    The trick with the original style rail is that to install it properly you have to split the boat. It's riveted to the bottom of the hull from the top before the cap is put on. The rail was wrapped around from the front and down the sides, the cap was slid forward under the lip, then the parts that wrap up to the transom were riveted from the outside.
    The rail is no longer produced, almost impossible to remove intact, and even more difficult to reinstall correctly. Unfortunately the black rubber stuff is the best replacement if your original is missing or damaged...
  14. Likes Capt.Insane-o liked this post
    Jan 2005
    New York
    Does the Rub rail offer any type of fastening the deck to the hull??
    Patriot Missile
  16. #13
    Jan 2009
    Lafitte, Louisiana/ Beaumont, Texas
    I know of a few people including me that used a 1/4 to 1/2 vinyl rubrail from McMaster Carr.
    Modded Hydrostream Vking
    Hydrostream Vking
    Hydrostream Viper
    Sold, Hydrostream Vector, Allison xb2002
  17. #14
    Jan 2009
ID:	461838Click image for larger version.
    Hydrostream Vking
    Hydrostream Viper
  18. #15
    Sep 2017
    Miami
    If you haven't found any yet, I've had luck with more obscure designs with these guys. https://www.integritymarinecorp.com/
  1. Hydrostream Venus
    By R.I.P. in forum General Boating Discussion
    Last Post: 05-27-2021, 11:26 PM
  2. Hydrostream Venus?
    By HopperRoy3 in forum General Boating Discussion
    Last Post: 10-09-2014, 08:48 AM
  3. Hydrostream Venus set up
    By R.I.P. in forum Props, Setup, and Rigging
    Last Post: 06-19-2010, 12:02 PM
  4. hydrostream venus xt max hp
    Last Post: 08-05-2009, 11:08 PM
