Results 1 to 15 of 47
Thread: Crankcase compression??
03-19-2020, 08:42 AM #1
Has anyone actually measured crankcase compression?
The amount of air between on the inside of the piston to the reeds.
I'm curious of what it would be.
I'm relating it to boost such as turbo boost or blower boost. Because from the combustion chamber point of view all it knows is that air-fuel is being forced in .
So what kind of PSI do ya think is in the crankcase of various motas? And it would be neet to know before and after numbers of the same mota with installing intake stuffers.
03-19-2020, 11:51 AM #2
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,946
- 587
- 100
- 514
- 621
I Dont think there is any real compression, just air flow. at high rpm the reeds stay basically open,once the column of intake air gains momentum. oil injection works using case pressure, just a few lbs. i could be wrong...
03-19-2020, 12:27 PM #3
roadkill636 thanked for this post
Instigator liked this post
03-19-2020, 08:17 PM #4
I put a gage with a checkvalve on 1 cylinder of a 225 merc promax and it read about 4-5 at idle and 7 when you reved it on the hose #s were quite abit lower on a 3l omc.
powerabout liked this post
03-19-2020, 10:07 PM #5
H20... where were you able to hook up a guage?
And with a 7 peddle front. Do you think the compression could get to 6 or 7 on a 5 peddle front?
03-19-2020, 10:21 PM #6
Member
- Dec 2006
- Central Wisconsin
- 81
- 7
Maybe read pressure at the oil injection pulse fitting that usually just gets blocked off?
KIRCHNER thanked for this post
03-20-2020, 06:25 AM #7
Really long time ago but i think i used the low pressure diaphragm fuel pump fitting on both engines , the promax was a 99 so it had 5 petal cages.. Its a factor of case volume, if your asking what the difference in the 7/5 petal front volumes with the cages in is i have no idea, im sure the merc gurus can chime in. I mainly did it to compare merc to omc to see how much less the omc had with the much bigger bottom end volume. My test was certainly crude... the check valve spring and hose volume would all play in the numbers... I did read there is a point of diminishing returns but i dont think you could get to that point on an outboard, I rebuilt a few Honda cr500 engines and the crank to cases are as tight as it gets with just enough room for the rod to run between the crank cheeks and thats it...
David - WI liked this post
03-20-2020, 02:44 PM #8
Unless this is some type of supercharger, then it can only put out what it's being powered by ...
So ifin ya gotz 5 psi of fuel pressure, chances iz purty good ya gotz 5 psi of vacuum runnin it from the other side ..
Chaz = thinkin that they figged out that they dont need the crank swingin thru the bottom of the grand canyon ... they used that volume at the mouth of the transfers and up thru the funnels .. where it would do some serious good ..
03-20-2020, 06:17 PM #9
Chaz... can't have "
5 psi of vacuum", vacuum is negative pressure.Checkmate 2002 Convincor 270 496 MAG-HO
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
03-20-2020, 06:31 PM #10
Banned
- Jan 2015
- Wisconsin
- 2,327
- 458
- 343
- 6429
- 5148
- 4 Post(s)
Actually, you can. A few ways to measure vacuum and psi is one of them.
https://www.setra.com/blog/vacuum-pr...you-measure-it
03-22-2020, 02:15 PM #11
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
No positive pressure is generated. Map sensor always reads less then 14.7psi.
if any is created it’s only from piston tdc to intake open.
their is a fan effect and centrifugal mass acceleration.
03-22-2020, 02:24 PM #12
Map is in front of the reeds... like chaz said u dont get something for nuthin..
03-22-2020, 07:27 PM #13
Part of what I have so much fun with inside a 3.0 OMC looper.
Some nylon plugs, a pint of epoxy, some flow workI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
H2OPERF liked this post
03-22-2020, 07:41 PM #14
A pint that's it
03-22-2020, 08:12 PM #15
H2OPERF thanked for this post
Crankcase compression for experts
By Terry Jackson in forum Technical DiscussionReplies: 155Last Post: 06-22-2020, 04:01 PM -
playing with crankcase compression?
By R.grover in forum Technical DiscussionReplies: 0Last Post: 06-23-2013, 04:40 AM -
Mercury Tech: Hey T REX (crankcase stuffing)
By Bryan Heaberlin in forum Technical DiscussionReplies: 21Last Post: 12-19-2008, 11:05 PM
