Page 16 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 226 to 240 of 273
  1. #226
    The x wasn't that great of a motor. A lot was left on the table with that one.
  2. Thanks baja200merk thanked for this post
    Likes Dave Strong liked this post
  3. #227
    But it had great potential.
  4. #228
    So I took a set of 14* Dart/Olds/GM part numbered heads to a friend of mines Cylinder head / manifold porting shop in Ft.Lauderdale to put fresh eyes them. He put a light spring on a pair of stems and took 5 or 6 readings on each side up to an inch of lift.
    When he was done, he said grab one of those hemi heads (a pallet load of BAE heads)
    and put in on this table .. he said, tell me what I should do to these to make them better. I said dude, your my teacher .. I don't really see anything that doesn't "look just right" .. He said exactly, I can't do anything to yours to make them any better either .. which made me feel a little better about the time I spend pouring rubber port molds , moving a wall or roofline up or over, bench testing it , pouring more rubber, changing the throat percentages ... etc etc etc ... and by then, I was finding and losing crumbs, no more big gains ..
    My point .. It's hard for even the best to find improvement in highly developed pieces. But if you start out with a POS that was machined on 50 year old tooling by people who could give a **** about anything other than getting a paycheck. You could just about trip and fall into big gains in power and reliability ...
  5. Likes Dave Strong, johnmiffco liked this post
  6. #229
    Jan 2006
    Pompano Beach, FL
    I agree but EPA pretty much killed any further hp gains from Mercury. Motor was going to be their 400hp two stroke.
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  7. #230
    Jul 2004
    houston,tx
    speed on water just released an article
    new 2019 28 skater flat deck rigged with the new 300r 4 strokes
    grant racing (which is 1 of the best out there setting up offshore race hulls) and with the mercury racing team
    took boat to lake x couple weeks ago,,,,
    and did full testing with many props and gear case changes,,,,1.6 and 1.7 ratios
    the best it did was 114mph with 1 person and lighter on fuel
    111 with 3 people and 1.6 gear,,,,,108 3 people and 1.7
    in article shows all specs of props and gearing to mph and time to get there
    so,,,,,now that's a new 28,,,,not old 90s model,,,,,new motors and the best people and props and cases
    an old 90s 28 skater ((( little moisture in the core,,,mabe repaired a few times,,,painted a time or 2,,,ect,,,so prob a bit heavier
    with 3.2 300xs common dialed in hull is 112-114,,,,some faster with bolt on parts and tune
    with 3.0 300x common is 114-116,,,,and of course some faster 118-120
    with the 2.5 280 common is 113-115,,,,,lighter motors and more rpm,,,
    so now in 25 yrs of these 280/300 merc motors on same hull through the yrs
    don't see much true difference of the new 4.6 4 stroke for the money
    vrsing the (old junk) 2 strokes of yester yr,,,,,
    280 being the simplest and lightest motor 380lbs to the 300 4 stroke ,,merc list at 515 but randy weighed with cowl @ 550lbs
    now the 4 stroke is all we have new so gotta deal with it when want new
    but ,,,,,,,,the old junk 2 stroke is simpler and can make big power very easily over stock trim for very little extra
    for now ill stick with my 98 28 im restoring with 300x design motors,,,but are being bumped up with standalone, porting and comp,,,3.2 crank and 40 bore to 3.3 to pull larger prop and have less money spent on buying and building both motors than cost of 1 new 4 stroke
    just my 2 cents
  8. Thanks mikesufka, tom kennedy thanked for this post
  9. #231
    Jun 2001
    Crosslake, MN
    Very interesting !!! Thank you.
    MDS
  10. #232
    FLA
    Are the new Skaters slower or whats up . 28 Nordic went 113 with 300R . Every DW 28 Fat Cat has gone over 120 with 300s Heck with 4 of us Skater Dave , Brad Z. Myself and 1 more passenger we went 114 and was still climbing with Dave driving the boat the very 1st time. And we only had the Hill 5 Blades if only Mercury would loan me some of their 5 blades .
    24 Twister
  11. Thanks baja200merk thanked for this post
    Likes baja200merk liked this post
  12. #233
    Jul 2004
    houston,tx
    don't have that answer on slower being new,,,,is flat deck with full wrap windshield vrsing older out of mold hulls
    i just relayed the articles results of a lake x test session
    of the new 28 with 300r and the common speeds of 25 yrs of same hull and 280 and 300x,xs
    this thread is comparison of the 300r and 300xs on same hull and the 28 been around since the 90s through mercs yrs of motor designs
  13. #234
    FLA
    I did not know it had a windshield just looked at the article That does slow them down always wanted to try the DW 28 without 1 but it is no fun installing and once it is on there you don't want to do it again .
    24 Twister
  14. Likes baja200merk liked this post
  15. #235
    Aug 2012
    Tenkiller Lake, OK
    The 28 Skater flat deck that was tested a Lake X was stated to weigh 5000#. That is approximately 1050# heavier than my 2013 28 Skater std. deck w/ Aero Marine windshield. I think the weight is the factor.
  16. Likes mikesufka, Rigaud liked this post
  17. #236
    Jan 2006
    Pompano Beach, FL
    I agree that at 5000lbs it is very heavy. Also need to note it is not a stock 28 configuration but a widened tunnel. The additional weight in a boat like that equates to about 2mph per 200lbs. Not to mention the downforce of the windshield. Lastly this is a real verified test done at Lake X with real information. Not a bunch of numbers being thrown around about what someone else's boat runs LOL. The DW 28 is not a fair comparison to the Skater as it is lighter and the sponsons are much more shallow on the angle of attach. I do not think the DW would run with the 28' in rough water. JMO
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  18. Likes johnmiffco, Davidlake liked this post
  19. #237
    Jul 2004
    houston,tx
    agree ^^^^^^
  20. #238
    Total different boat then the classic 28 Skater. Not a fair test. Same boat different motors is the only fair test
    21 Intimidator 300x Sold
    http://www.youtube.com/watch?v=KBoYUJ58sLE
    1/2 21 Skater 300x Sold
    http://www.youtube.com/watch?v=tKNFL8b6kWo
    30 Activator 850 HP Sold
    https://youtu.be/NZgOTNGKzqg
    30 Concept Twin 300Rs
  21. Likes Z06man liked this post
  22. #239
    FLA
    Randy has had 300xs and 300R on the same boat 21 and 25 . Steve's Bullet changed out on same boat Allison Bass boat posted his results with fuel load acceleration etc same boat .24 Skater changed over they all have posted there results . All had gains some way more than others. Dont know of people changing from 300X to the R. I probably will this year on my Twister . I have a 40 hour from new 04/05 300x with a brand new 1.62 from swapping out a 1.75 with carbon pan and cowl going up for sale this summer .
    24 Twister
  23. #240
    Jan 2006
    Pompano Beach, FL
    Keep your 300x. There are advantages of the new motors in fuel mileage, being dock friendly etc. However if you prop your 300x for 7000 max rpm IMO the 300r will not keep up in acceleration. Problem is in order to get the top speed like the test showed you need the 1.60 gear and a large prop as the limit is 6400rpm. The guys at Lake X told me the sweet spot for the 300r is 6250 for max power. 33sec from 40-100 mph is pretty sad considering my boat will do it in around 20 seconds. I have no argument the the 300r is better than a 300xs. All day.
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  24. Likes Z06man liked this post
  1. Fastbass Marine TV - Mercury Racing 300XS vs 300R
    By river rocket in forum General Boating Discussion
    Last Post: 10-22-2019, 08:32 AM
  2. Part # For boat side harness for 300R
    By aggiestckl in forum Technical Discussion
    Last Post: 08-18-2019, 12:46 PM
  3. Replies: 24
    Last Post: 12-26-2018, 09:32 AM
  4. 2007 liberator 21 300xs 190hrs rare solid red boat freshwater boat
    By Mercaholic86 in forum Hulls larger than 20'
    Last Post: 10-31-2018, 01:44 PM
