Results 1 to 15 of 19
Thread: Mercury 60R
    Jun 2018
    New York
    Mercury 60R
    Looks like Mercury is making the 60R available in the States again with nice props , could some one splash a light weight pad Rocket for it.....
    i'm sure a a few would sell with room for a nice profit in this economy! https://www.powerboatnation.com/merc...at-miami-show/
    Mar 2015
    Vancouver, Washington
    What is the theoretical top speed at WOT with the tallest Prop available from mercury, and the tallest gears available? Assuming there was a hull that would allow the motor to achieve that?
    Whitney Woolard
    Oregon/Washington
    '96 Allison XB2003 w/Mercury 2.5 260ss
    Is that spitfire 4 blade ss still a 15 spline small barrel, fit an old inline?
    Flu motor.
  5. Likes powerabout liked this post
    Jun 2018
    New York
    They do 74 MPH on lightweight race tunnels.
    Dec 2006
    Central Wisconsin
    I don't understand this engine. Why the big gearcase with 2.33 gears? Wouldn't the smaller gearcase with the taller gears be the better choice for speed?
    Tiller , 15" , stump bashing lu, work motor
  9. #8
    Mar 2009
    Saint Lucie Florida
    The formula race 60 is the race engine, they are similar but alot different. The new 60r is marketed as a small flats boats engine that is very popular nowadays. They needed to fill that hp range with an "R" motor. There are no other 15" mid motors in this hp range in the market merc is trying to get in on it. The difference between this engine and the Formula race is:The new 60r is 20lbs heavier, ( likley due to gearcase) The 60r has a 2:33 gear box and is huge at 4.25" formula race has a 1:83 at 3 3/4"
    , the formula race has solid motor mounts the 60r does not, the formula race has wing plate mounts on the mid and comes with wing plates, this 60r does not. Both have 6300 limiter and likley tuned the same so its a step up from fishing motor. Fishing motor makes just over 60hp at 5800 rpm, the formula race and presumably 60r make closer to 70 at 6300. 60 r can have up to 5 year warranty, formula race, no warranty. i like this idea, im hoping it helps push other manufactures for make small race style engines again, Etec 60 should come with 15" mid and a small race gear ratio lower unit! hopefully this puts the competition out there. I must add these engines are extremly reliable given they are actually made in china, at least they were, they may have switched with this new 60, but I have seen this powerhead with over 10,000 hours on it... yes thats alot.
  10. Thanks Mini GT thanked for this post
    Dec 2001
    Too me a Merc 600/Mk75 was the last of the DKbusters.......700 and 800 were 66 cid and 76 cid...... did I land on the wrong planet???? Hee hee........ stump my toe on a Merc 1000ss........FGS?
    The 40-50-60 should be built in the US.
    Aug 2013
    Oshkosh, WI
    Quote Originally Posted by 90VIPER View Post
    Bigger gear case acts as a planing surface combined with bigger props for much quicker hole shot than the smaller gear case on the Formula 60. Add in the higher rev limit and 2.33 ratio and it is an animal out of the hole, especially in shallow water conditions where it is being marketed (flat skiffs).
    2000 Triad Mod VP 280 ROS
  14. #12
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by Petey View Post
    The formula race has the same 6,300 limiter, not sure why it says 6,000 on their website.
  15. #13
    Aug 2013
    Oshkosh, WI
    Quote Originally Posted by TwzteD View Post
    They are different programs, 6000 is the soft limiter on the formula race, the 60R has a soft limit at 6300 and a hard limit at 6500.
  16. #14
    Nov 2019
    Canada
    I'm not totally sure what's with the "Race" branding on the motor. Maybe just because of the Formula Race 60? I'm not sure why they didn't just call it a Pro XS, bring it out in a 20" and a 15". I would bet on it that a 20" is coming shortly, as I'm sure this motor's true intention is to compete with the Yamaha & Suzuki 70hp, as well as the Evinrude 60HO, on fishing rigs.
    www.InjectorService.com
    Call/Text - 204-326-0390
  17. #15
    Bucyrus OH
ID:	459079 I need one for my boat.
  1. Mercury key switch harness conversion for old school inline six Mercury
    By Phil Conant in forum Misc. Parts and Accessories
    Last Post: 06-04-2015, 06:34 PM
