Results 1 to 10 of 10
02-05-2020, 08:50 AM #1
Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
2.4 non finger ported piston in a finger ported block.
Can you do it and what will you loose? I am assuming you will loose the advantages of the finger ports, but it should still run as good as the 225 non finger ported blocks? I have 6 NEW non finger ported, standard bore pistons for chrome bore that i am thinking of using in a spare motor.Anyone done it? Thanks
02-05-2020, 09:54 AM #2
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,630
- 301
- 279
- 1791
- 1275
Drill the holes for finger ports...
Capt.Insane-o liked this post
02-05-2020, 10:00 AM #3
Member
- Oct 2009
- Lake Conroe, Tx
- 63
- 30
I thought about that, but don't think i have the equipment or expertise to do it.One looks simple, the other a bit more difficult. Food for thought though.
02-05-2020, 03:43 PM #4
let a machine shop cut pistons on mill. U will b glad u did , those ports help alot
And have em D cut the piston port or square, better yet look for cherry 2.4 project and look at the pistons pic , reported great hp gainsLast edited by Merc 2.5; 02-05-2020 at 03:45 PM.
02-05-2020, 05:11 PM #5
02-05-2020, 05:49 PM #6
Screaming And Flying!
- Dec 2001
- 9,487
- 271
- 191
- 1979
Buy a Cheep drill press $ and a mill vice and do it ya self.....In the end you have a drill press.....I don't D port em.... round is better.... just radiuse.. the top.....Some of the real early....2.4 non finger port slugs were kinda thin in the casting.......when they first came out......
02-05-2020, 07:34 PM #7
02-06-2020, 12:57 AM #8
- Dec 2001
- 9,487
- 271
- 191
- 1979
To cut heads..... no.... a Drill press don't have the capable control for that big of a cut/ work. If ya need heads cut I have a bigggg drill press...... bridgeport........ Just send with how much ya want cut.....you may have to final lap them by hand......to make them as nice as a mirror. I don't CC heads......that's up to you.......but before I cut in try to un/warp before cutting to get better chamber even ness.......
02-06-2020, 07:02 AM #9
And hell you only have 6 so..
I would make sure that if you have someone do them they will match them to the motor. why I said good machine shop.. difference between machine shop and machine shop that does modifications etc....you'd be surprised..
The little things you just assume..
Like when I was talking to a 30 mechanic asked him if he was putting a nose cone or low water pickup ... Had no ****ing idea what I was taking about.. but could build/rebuild a motor in his sleep
Michael
02-06-2020, 04:39 PM #10
Didnt think it would work , but I could see where a setup like that comes n handy
1993 225 looper finger ported block
By anthony714 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 03-18-2017, 07:43 PM -
finger ported crossflow
By ultrafast in forum Technical DiscussionReplies: 18Last Post: 10-31-2014, 08:29 PM -
Finger ported 200 XP
By phil blomquist in forum Technical DiscussionReplies: 16Last Post: 09-29-2009, 09:17 PM
