Results 61 to 75 of 145
01-31-2020, 06:55 PM #61
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
02-01-2020, 03:35 AM #62
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
Merc HP props came in even#s... a 23??? chopper? not so quick to buy I hope...Show picks before ya buy.... That old merc has a small shaft....so most choppers will not fit....unless a merc 25 chopper... hard to find and wrong splines.......Pete Delacker had a prop that might work.....He is not with us... he has passed.....but his son might have said prop......
02-01-2020, 08:45 AM #63
At least you figured out auto fill changed pitch to ouch??
Yes, the smaller the prop, the harder to find.
Spline count is the key.
A Chooper (be sure that’s really what you have as they’re miss listed all the time) has a lot of bow lift built into it which you don’t want/need. If it’s cheap, try it anyhow.
Most likely a cleaver will run better on your rig. Most have very little lift built into them.
Your hull has all its lift built into it.
I ran 23” pitch x 1.6 gears x 5000 RPM x 10% slip and got 60 MPH.
That may be close.
Depending on how everything works together and how healthy your motor is, you may see more.
5500 = 67 and 6000 = 74
Depending on your plans for the rig, if it is to be more than a one time toy, you might want to start collecting props.
Way easier to try 3 or 4 props when you have them w/you.
Another tip is to build a test horse for the boat.
Basically a metal saw horse (iron plumbing pipe works well) so it doesn’t float away, w/carpet on top where boat will set.
Set it in water, just off the shoreline.
Deep enough water where prop is just out of water when back of boat is on the stand.
One guy on either side of motor will easily lift it onto stand.
There it will be easy to change props, set up, driver, add fuel etc.
Youre also not clogging the ramp.
Youll also likely spend time experimenting w/engine height and trim angle.
Have you engineered a fuel tank yet?
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
02-01-2020, 12:56 PM #64
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
[QUOTE=Instigator;3186397]
/QUOTE]
I'm sorry, I misread. It is a Ron hill 13 spline 12 1/2" x 23p cleaver not a chopper. Hopefully that is enough ouch 😜. He says he also has a 24 and will trade it as long as I pay shipping. I'm thinking about jumpin on it and seeing what it does. Attached are some pics of it.
As far as gas tank goes I was just planning on running a 6 gal portable strapped down.
tnelsmn liked this post
02-01-2020, 01:53 PM #65
Looks good.
Ron is a good guy and used to race that style boat too.
He also used to be a school teacher and likely will want to help if he knows your story.
Problem w/the tank is where to put it and it’s weight.
They make some smaller, plastic tanks for against the inside of the transom on dinghies.
Location wise, that would be perfect.
I doubt they will fit your narrow cockpit though.
Probably around 16” ???
Anywhere forward is worse case scenario. It will hold the sponsons on the water, preventing their lifting, and will scrub speed.
[QUOTE=Seanj85;3186445]Last edited by Instigator; 02-01-2020 at 01:56 PM.
02-28-2020, 03:48 PM #66
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
Well its been a few weeks since I posted. We have been getting into the finishing process with fairing, glassing, staining and varnishing. We closed up important seams w epoxy and some woven strips of glass. When necessary we made some fillets w cabosil and glassed them over. I tried to limit the amount of glass and epoxy as it weighs a ton and we are already overbuilt. Attached are some photos of our progress.
02-28-2020, 03:51 PM #67
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
02-28-2020, 05:40 PM #68
- Dec 2001
- 9,501
- 271
- 191
- 1979
You can not be over built...... only under powered.........
02-28-2020, 07:37 PM #69
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
02-28-2020, 07:40 PM #70
Congratulate those kids for me Sean. That's really impressive. You should be proud.
RockTeam Junk
Instigator thanked for this post
02-28-2020, 07:53 PM #71
5000 RPM
- Apr 2015
- Oceanside, NY
- 155
- 20
- 10
- 51
- 119
02-29-2020, 07:23 AM #72
Killer!
Good call on the finishI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
03-02-2020, 07:14 PM #73
looking good!! Glad to see younger kids doing something other than playing on there phones
03-03-2020, 06:10 AM #74
Looks awesome, great job. Lifetime memories for most I'm sure.......
Seanj85 liked this post
03-04-2020, 09:52 AM #75
5000 RPM
- Apr 2018
- Maine/Ma
- 223
- 81
- 10
- 132
- 56
Looks Beautiful......awesome to see a shop class take on something out of the ordinary. When i was in high school back in the 70's, my Dad and I built a Glen-L "T-N-T" as a winter project in our garage, was the best Father-Son project. That spring I did a class project on the entire build (wish we had the photo ability we have today back then). Teacher was so impressed he asked me to bring it to school and show it, had the entire class out in the parking lot.
Great job kids, keep up the awesome work, and can't wait to see some vids of her in action!
OMC Tech: School Me On Old School ('50's) 2 Banger JohnRudes......
By Instigator in forum Technical DiscussionReplies: 32Last Post: 01-14-2015, 07:48 AM -
Hydroplane,,an old one.
By Eagle127 in forum General Boating DiscussionReplies: 18Last Post: 03-09-2013, 09:00 AM -
Old School V.S. New School Paint
By EVILWAYS in forum General Boating DiscussionReplies: 138Last Post: 07-29-2009, 02:24 PM -
jet hydroplane?
By KEVIN NICHOLS in forum Technical DiscussionReplies: 11Last Post: 04-01-2003, 06:57 PM
