Results 1 to 15 of 16
Thread: Verado powerhead conversion
01-14-2020, 07:05 AM #1
89LASER liked this post
01-14-2020, 07:06 AM #2
make the powerhead lay longitudinal and not vertical
01-14-2020, 08:47 AM #3
The Historic Photo Master
- Jan 2004
- Florida
- 38,704
- 78
- 1772
- 384
- 20446
- 4 Post(s)
u will definitely be the first to even think about doing it, I assure u...
01-14-2020, 09:32 AM #4
watch this...awesome!
InjectorService liked this post
01-14-2020, 09:56 AM #5
This is down the street from you, bolts right up and makes enough power to run the crash box and hydraulic pump.
As well as probably be cheaper and a lot less disappointing, in the end ...
https://www.shafiroff.com/chevy-pump...isted-sr20.php
01-14-2020, 03:45 PM #6
your going to have a tough time laying a verado on its side, its go no where for the oil to get back to the pan then.
I would say your better off with a 3.0 efi or dfi powerhead.1988 Checkmate Starflight Yamaha 3.3L OX66
noli liked this post
01-14-2020, 05:17 PM #7
Curious, does anyone know where the oil pan is for the Verados ?
Anyone have the engine schematics?
01-14-2020, 05:51 PM #8
www.InjectorService.com
Call/Text - 204-326-0390
01-14-2020, 06:03 PM #9
Pick-up tube, sump is below the engine adapter plate ...
https://www.mercruiserparts.com/bam/...2715/16769/175
Oil pump, drive, etc. is above ...
https://www.mercruiserparts.com/bam/...2715/16769/160
01-14-2020, 09:20 PM #10
01-14-2020, 09:54 PM #11
Oil drain back from the crankcase cover and cylinder head, and the separate scavenging pump you will have to run, bell housing, engine coupler and water pump.
01-14-2020, 10:02 PM #12
I think the oil will drain back both by gravity and positive flow from source. The oil reservoir will be below the motor.
an electric non-scavenging oil pump will be used
fabricate - bell housing, engine coupler
en electric non-scavenging water pump
01-14-2020, 10:18 PM #13
That's a lot of work for 300 horsepower, and you haven't even got to the exhaust yet.
01-14-2020, 10:26 PM #14
01-14-2020, 10:52 PM #15
and a dummy drive for the cam chain due to oil pump removal.
Verado/transom water pickup/powerhead plumbing
By Steelborn in forum Technical DiscussionReplies: 0Last Post: 06-25-2018, 07:13 PM -
2008 Mercury Verado 250HP Dressed Powerhead
By MERCSPEED in forum Outboard EnginesReplies: 0Last Post: 11-18-2015, 04:45 PM -
Mercury Tech: SST120 powerhead EFI conversion
By madgadget in forum Technical DiscussionReplies: 2Last Post: 09-03-2013, 08:59 AM -
My new scarab w/verado , any upgrades on verado 250 ?
By cc@100mph in forum General Boating DiscussionReplies: 21Last Post: 08-03-2010, 06:28 AM -
Mercury Marine and Mercury Racing Product Report: 300 Verado, 200 I-4 Verado, 1200SCi
By Scream And Fly in forum General Boating DiscussionReplies: 68Last Post: 02-21-2007, 07:56 AM
