Results 16 to 30 of 39
    Jul 2005
    AZ
    Quote Originally Posted by johnlysh View Post
    Kevin is your man. He has put the time in to figure out what works and is trouble free. Probably have 200hrs or more with a sporty under an omc moded by him.
    I pmed him earlier just waiting to hear back.. sure he's busy so..
    You have any pics or anything?
    Michael
  2. #17
    Mar 2009
    holiday
ID:	456173Click image for larger version.
ID:	456173 only various pics of it under a motor on various boats
  3. Thanks mrichartz thanked for this post
  4. #18
    Mar 2009
    holiday
ID:	456174Click image for larger version.
ID:	456175Click image for larger version.
  5. Thanks mrichartz thanked for this post
  6. #19
    Jul 2005
    AZ
    I just sent my mids out to Mike Chapman to get them done.
    And the lowers are the next project. Want to get pricing etc to figure out how long
    Pics are of newer mids I'm getting my 88-92 mids done
    Michael
  7. #20
    Mar 2009
    holiday
    Looking good.
  8. #21
    I weld up the merc bolt pattern and redrill it to omc then do the shaft and make the omc water pump work so it’s as factory as it gets. We logged thousands of miles I’ve converted about 15 so far it’s an expensive process but with the right setup it’s can be worth 15 mph thanks to the gear. With my big prop it does 90mph at 4700 and I’ve been 118 (in less than ideal conditions) at 5800-5900 with way more to go. The big prop has broken a lot of sporty parts so I usuallt just ride around with a 30 which still runs high teens at 7k
  9. Thanks mrichartz thanked for this post
  10. #22
    Southside, Al.
    Was just recently reading a conversation on here that a coned lower is actually a tad faster than a sporty. If that is true, why go thru all that cost and time ?
    JMO
    Looking for who does the adpaters for
    Putting Sportsmasters on an omc and any links to posts that have done it..
    I had all the links and somehow lost them.
    Thanks Michael
  11. #23
    Jul 2005
    AZ
    Quote Originally Posted by berdes View Post
    JMO
    Actually depends on what your doing read baja200merk post they use the 1.62 gearing and will be much faster..
    But I
    Should have worded title different but..
    Looking into what will hold up to being surfaced
    Best, is actually what I want.. it may just be what I've got is what I've got...mine are pinned and change the fluid often.
    I had one go on me from surfacing it, but might just be it and to bad..
    And might just be cheaper to buy/rebuild a lower if it goes again
    I can't use that kind of gearing because of my motors.. compression , porting and weight.. need the 1.87
    Michael
  12. #24
    JMO
    Way too many variables to make that claim. Sportys work well 2” above the bottom. The main benefit is the big gear but we just got the first set of 1.60 gears for m2 etec cases which i plan to prove the fact that the type of case or shape does not matter when it’s not in the water. Decent skeg and torque tab will run with no nose cone. I’ve already been 105 with no cone it doesn’t matter because it’s bone dry anyway.
  13. #25
    daytona beach
    This is a video of my sporty/etec on the mirage i use to own. Kevin adapted this one a while back. As you can see not much case is in the water. I am running a 1.62 and 32 et in the video. I do believe the sportys hold together better than stock omc stuff but I would keep an original case with a cone if you are wanting to stay with stock gear ratio. Biggest advantage is going to be
    The ability to goto a 1.62.
    https://youtu.be/8Vu1Wx1o4tY
  14. Thanks baja200merk, mrichartz thanked for this post
    Likes mrichartz liked this post
  15. #26
    Will you be using a transom pickup for water?
  16. #27
    Jun 2002
    Winter Haven Fl.
    Kevin where did you get the gears? Have them custom made?
  17. #28
    no The m2 has a water cavity in the nose so all you have to do is close up the 6 factory holes and drill one by the drain hole for that cavity it puts the water pickup as low as a sportmaster on the bottom of the cone. That’s how I got water yrs back on my t1 with an m2. The limiting factor was 1.85 gear now we fixed that with 1.60
    Quote Originally Posted by oldschoolltv View Post
    Yes the conversion will be drastically cheaper than a sportmaster. It requires big diameter and high engine height since the m2 is rather large.
  18. Thanks powerabout thanked for this post
    Likes powerabout liked this post
  19. #29
    locked in gear but maybe we should graft a bravo lower on and then maybe a bravo duo prop?
    ( ok a bit of work to get the water pump setup)
  20. #30
    Bravo is heavy and part of the gear Change is in the upper plus like you said no water pump. M2 is sout and the carrier is not round so it can’t spin.
  1. 3.0 Sportsmaster
    By ASPB in forum Lower Units
    Last Post: 07-11-2015, 01:46 PM
  2. Mercury Tech: sportsmaster
    By Superbender in forum Technical Discussion
    Last Post: 09-04-2009, 12:51 PM
  3. sportsmaster
    By water in forum Technical Discussion
    Last Post: 05-20-2008, 07:30 AM
  4. sportsmaster
    Last Post: 04-25-2008, 08:08 AM
  5. sportsmaster
    By tizcri in forum Technical Discussion
    Last Post: 08-03-2007, 07:11 PM
