Results 2,986 to 3,000 of 4053
Thread: Fastest SOB hull???
12-27-2019, 10:18 PM #2986
12-30-2019, 07:05 AM #2987
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,384
- 1082
- 421
- 4804
- 2207
- 9 Post(s)
Weight and size no longer an issue OMC just 30 years too soon
12-31-2019, 11:45 AM #2988
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
Allison as we all know makes some legendary boats. I forget the deadrise of the new XB21's V at the transom but I think it is 22 degrees. The freeboard and the bow deadrise however would never allow it to play in true rough water which is what the boats on this thread are about.
You would be real wet when things got snotty. Or you would be sunk.
Below is a photo of the bass Allison XB21 and then another that shows how deep you sit in one of the rough water SOB's along with a video of it underway.
https://www.youtube.com/watch?v=eKyr...ature=youtu.be
12-31-2019, 11:50 AM #2989
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
Progression 22 in first shot, Bernico Extreme 21 in the second shot, Nordic SR-21 in the third and then a Tuff 21 in the fourth.
Allison XB21 in the row below. XB not going to work in rough water.
TooStroked thanked for this post
TooStroked liked this post
12-31-2019, 01:42 PM #2990
The tuff 24 with 300xs at 116 mph should be at the top of this list
2023 TUFF 25
01-01-2020, 06:44 PM #2991
powerabout liked this post
01-01-2020, 09:01 PM #2992
Greg G liked this post
01-02-2020, 12:35 AM #2993
I'm not an expert in this type of hull design, but is a Nordic and Bernico in the same class as Progression when it comes to rough water? I have been to the Nordic factory to look at the 21 and didn't think it would handle any bigger water than my Allison. I will not dispute an Allison is going to run in Progression water. Truly impressed with what Tuff and other boats mentioned can run with a single. Really cool to read this thread.
Allison XB21 2+2
01-02-2020, 04:05 AM #2994
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
2020's Fastest SOB Rough Water Hulls Powered with stock Mercury 300R 4.6-liter naturally aspirated V8 (6400RPM, No Dyno Yet)
#1 Labsport VF2 21 – Confirmed 94MPH Driver 28SkaterCa
Fastest SOB Hulls Available For Purchase New Back In 2019....All Boats Powered with a stock Mercury 300XS (306HP and 6400RPM Limiter)
#1 Tuff 21 kevlar hull-890lbs– 20’8” Long, 7’7” Beam - 22 degree deadrise + 7 1/2" pad - Confirmed 105.9MPH Driver Blake Sewell Canada
#2 Bernico F2 21 standard hull-727lbs– 21’4” Long, 6’3” Beam - 24 degree deadrise + 14” pad - Confirmed 98.1MPH Driver Dave Van Steelant
#3 Progression 22 standard hull-948lbs– 22’1” Long, 7’8” Beam - 24 degree variable deadrise + 7" pad - Confirmed 94MPH Driver goneby
#4 Velocity V7 21 standard hull-682lbs– 21’4” Long, Unknown Beam – 22 degree deadrise + Unknown pad width - Confirmed 92MPH Driver 28SkaterCa
#5 Sutphen 21 standard hull-1325lbs– 20’9” Long, 7’2”Beam - 20 degree variable deadrise + 3" pad – Claimed 88MPH Driver Unknown (525 ran GPS 93.4)
#6 Nordic Crossfire 21/SR-21 standard hull-1475lbs– 21’ Long, 7’1” Beam - 18 degree deadrise + 9" pad - Confirmed 86MPH Driver wildone
And the fastest of the no longer produced hulls....with power noted;
#1 2002 Intimidator 21 -- Deadrise=22 Degrees + 6" pad. Confirmed 104.6MPH – Stock Merc 15” 300X(325HP) - Driver Trimmed Out15
#2 1985 Velocity 22 Stepp “Old Style Deck” -- Deadrise=22 Degrees + 12" pad. Confirmed 97.1MPH – Stock Merc 20" 300X(325HP)- Driver B kNo023
#3 1986 Superboat 21 Classic -- Deadrise=22 Degrees + 6" pad. Claimed 97MPH - Stock Merc 20” 300X(325HP)- Driver hoser
#4 1976 Challenger 21 -- Hull 1350lbs Deadrise=21.5 Degrees. Confirmed 90MPH - Yamaha 250 HPDI Phase III (326HP) - Driver Jamescole
#5 1990 Activator 21 -- Hull 1475lbs Deadrise=22 Degrees + 5 1/2" pad. Confirmed 84MPH – Stock Yamaha 250 Ox66 (256HP) - Driver dnelson964
#6 2012 Velocity US 220 -- Hull-1895lbs – 21’6” Long, 7’11” Beam - 22 degree deadrise + 12" pad. Confirmed 83.5MPH – Merc 300XS - Driver aaronmt7
01-02-2020, 04:23 AM #2995
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
The white Labsport VF2 21 pictured below belongs to a board member here and is already running in waters out West for months. Even with a ski race set-up, it has easily clocked 94 mph on GPS. Regardless of application set-up so far, right now it's the fastest rough water SOB with 300R power in the US.
I spoke with the owner just before Christmas and while I never got a hull weight, he said he is going to be trying out several different props to chase a speed number this year. He feels confident that 100 is in site with full social interior. He was good enough to supply a bunch of photos. It got rigged with a V8 300R with Sporty right upon delivery from Australia. The Oz hulls are evidently all running Torquemasters.
https://www.facebook.com/watch/?v=1015560588784399
01-02-2020, 04:42 AM #2996
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
The "other" orange Labsport 21 V hull below (the mono V is evidently a new design for 20 year old Labsport Power Boats) has been in the United States since 2016 racking up rough water wins in ski race set-up. It started with a 300XS and that motor got swapped out for a 300R, not sure if it has a Sporty or T/M.
Speeds have never been reported with either motor but maybe you can contact Mike A and ask him Az.
Here is a video of the boat underway https://www.facebook.com/mike.warpat...8279079322221/
01-02-2020, 05:03 AM #2997
Supporting Member
- Jul 2004
- Connecticut
- 6,273
- 519
- 209
- 1077
- 1131
01-02-2020, 05:15 AM #2998
- Jun 2007
- 9,384
- 1082
- 421
- 4804
- 2207
- 9 Post(s)
01-02-2020, 11:00 AM #2999
Who makes the tabs ?
01-02-2020, 12:56 PM #3000
2.5-21, talk to these guys, they did the rigging on that Labsport with the tabs you are interested in.
https://www.facebook.com/teamarchermarine/
Greg G., I know about the Labsport already running here, but the Red/White hull getting rigged in the other pic will be competing against him in Ski competitions.I CAN ALWAYS MAKE ANOTHER DOLLAR, BUT I CANNOT MAKE ANOTHER DAY
